Old 10-31-2017   #1
Jetjock
Jetjock's Avatar
Default Thermostat Installation
For those of you that have replaced the thermostat on the LT5, how did you get the thermostat to stay in place while postioning the the housing back on? Thanks!
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 10-31-2017   #2
Default Re: Thermostat Installation
Same as cliff... it's also easier to attach the short hose to the top of the thermostat housing and the radiator before attempting reassembly.
Here are some other tricks. Note the arrow or notch in the replacement thermostat as that is the direction the thermostat needs to face towards the radiator. Also the backside of the housing bolts are threaded through so you can shoot some PB lube on the backside of the bolts before attempting to loosen the bolts as they are prone to snapping. GC
Old 11-01-2017   #3
ssrszz4
I used a little bit of super glue it worked great.
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
Old 11-01-2017   #4
Jetjock
Jetjock's Avatar
Thanks. The problem, that I am having, is the thermostat still popping out of position even though I used the putty knife. It leaked like a sieve. Tomorrow, I will use some permatex on it and see how that works. I did this long ago and did not have any problems.
Which bolt goes into the bracket - the short one or the long one?
Roy L. Carman
NCM Lifetime #1468
Old 11-01-2017   #5
Jetjock
Jetjock's Avatar
Nevermind. I just answered my own question.
Roy L. Carman
NCM Lifetime #1468
