![]() Join Date: Apr 2004
I'm looking for some feedback on the Fidanza aluminum flywheel from people who have one. My understanding is in order to benefit from significantly less weight, one has to be willing to accept "some noise at idle. How many people out there have one and what are your thoughts?
Please keep in mind I understand the upside, I'm looking for feedback on the downside issues and your thoughts. Thanks. |
![]() Join Date: Dec 2003
It is a subjective question. The noise/rattle from it drives some people crazy to the point of putting back in the original. To others, the added benefit outweighs any noise. Their are still others that say they barely notice it, but then again they typically have no cats, an x-pipe, and B&B's so they barely here 747's going overhead..
#3 | |
![]() Join Date: Jul 2007
KT |
![]() Join Date: Aug 2005
mine's quite noisy...it doesnt drive me crazy (i already am) but very annoying...i heard somebody (rippie?)makes something that's halfway between the stocker and the fidanza...compromise??
at 1500-1800 rpm,it does sound like my tranny is ready to fall apart !! i was wondering if there is a way to trim the stocker a bit without weakening it? bj 91/1735 4:10 p plenum & ih borla exh,no resonators lucas injectors |
Anybody know anything about a "halfway between the stocker and the fidanzaa" flywheel?
Sounds like it could be a winner if it existed. |
#6 | |
The Rippie flywheel was a re-worked Camaro flywheel, nodular iron like standard flywheels. It weighed about 22 lbs (as near as I recall without researching it) It is still a single mass, weighs significantly less than the OEM dual mass.
Nothing you can do to lighten the stock dual mass. Quote:
I believe Callaway sold a Centerforce single mass steel flywheel also.
