Delete
![]() Join Date: Aug 2006
Intermediate shaft for 90 ZR-1 may be difficult to find. 92-95 shafts are common with standard C4 - rag joint Close to the coupler to the steering rack. Looks like 90 standard C4 intermediate shaft rag joint was more in the middle of the shaft and have resulted in interference with LT5 exhaust manifold - just speculating - resulting in intermediate shaft specific to ZR-1 model.
What is wrong with your original shaft? Perhaps you can buy closest looking intermidiate shaft and use parts to refresh your original? 86-91 intermediate shaft for standard C4. Note that it says excluding ZR-1. http://www.parts123.com/corvettecent...50f&ukey=15389 Last edited by secondchance; 09-10-2017 at 09:19 AM. |
I think you are right. I need the shaft that has the rag joint at the bottom- due to header interference.
Thanks for the info. |
#4 | |
Are you trying locate an intermediate shaft in the middle of hurricane Irma sitting in Florida? Last edited by secondchance; 09-10-2017 at 11:31 AM. |
Hope all is well with you...
I'm not sure if that is correct I replaced mine on my 91 with a low mileage 96 shaft. The MY 90 May be a one off like so many 90 onlys. Also some folks have used the z51 hockey puck style shaft as well but unsure if that was on a z. Be mindful on working in that area as if you rotate it too much while getting it out you could compromise the clockspring and deploy the airbag. That is decaled on the shaft as well but some time those rot and fall off (the warning decal) GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 09-13-2017 at 10:47 PM. |
