Old 09-02-2017   #1
Default DIY glass top repair?
The corner of Ami's smoked glass top was broken and glued(?) Back on. But, the repair is visible (maybe only to a blind man on a galloping horse...).
I think if there was a filler of some kind, I believe I have the tools to buff it out.
Can anyone point me in the right direction?
TIA
Paul
Old 09-02-2017   #2
captcorvette
Default Re: DIY glass top repair?
Paul give this a try. I have used it on T-tops, targa tops and jewelery with good results.
https://www.resinobsession.com/resin...the-difference
captcorvette is offline   Reply With Quote
Old 09-03-2017   #3
RICHARD TILL
Thompson Astro Tops
1422 Huntsville Rd
Florence, AL 35630
Phone number (256) 764-0659
Old 09-03-2017   #4
Paul,
There's Melrose T Tops in Cortland.
Old 09-03-2017   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
TIA
Paul
Better to buy a new one now and stop the frustration of dealing with a broken one.
ANY repair will still be easily seen by the blind person on the galloping horse, and cheapens the look of the car.
Those roof panels are subjected to a lot of torsional force as the car moves over bumps and potholes. Once it is compromised, it is likely to remain that way.
Yours can be rebuilt, or best to just use it as a core for return.
Melrose or Thompson as others said, both are fine as long as you select the factory replacement version.
Like Nike; Just do it.
Then enjoy the new top!
Marty
Old 09-03-2017   #6
U can't unbreak an egg.
Old 09-03-2017   #7
RussMcB
This is a bit of a tangent, but hopefully related enough ...
If you buy a protective storage cover for your targa top, look closely before ordering. I was very disappointed when I found my new cover left the vulnerable corners exposed. It's easy to set the top down on one of the corners and chip it. The cover doesn't protect them at all (see lower corners in this photo).
Also, I agree with Marty. My glass top came with a cracked corner, and I stupidly did a few track days with my car and the top developed more cracks. I shouldv'e swapped to my other top for those days.
My cracks are hidden (not very well) with black vinyl (like the decal material). It looks okay from 15' away.
Old 09-03-2017   #8
Mystic ZR-1
Mystic ZR-1's Avatar
The corners of the storage bag are left
"exposed" to allow it to fit in the fixtures
in the rear storage compartment
Old 09-04-2017   #9
RichS
I'd be curious too. Mine has a 1" crack on the front drivers corner. Along time ago I had a 95 I bought a Astro top for, was a big piece of crap compared to the original. Melrose has some good reviews but never looked at one up close.
RichS is offline   Reply With Quote
Old 09-04-2017   #10
efnfast
Ahhhh, that's why they do that. Thanks Doug.
