Old 08-14-2017   #1
Default Ignition Switch (On lower Column)
IS this the right part #?
ACDELCO D1405B {#01990116, 1990116}
I assume so, but some places say it is not compatible with our cars yet this is the parts number on Rock Auto
Old 08-14-2017   #2
Ccmano
Ccmano's Avatar
Default Re: Ignition Switch (On lower Column)
This is from the infamous White Racing site. They may be a lot of things but I have never known them to be wrong on their parts id. He shows the same part number although the color of the part is diffent. 1990116.
http://www.whiteracingproducts.com/i...oducts_id=1477
I'm not saying to buy from WR just trying to identify the correct part.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-15-2017   #3
yeah, that is what I am finding elsewhere now too.. I just need to order one
Old 08-15-2017   #4
WVZR-1
Buy "LOCAL" and just use the 1990116 as a reference for whoever you choose. At this point I doubt that other than buying a confirmed NOS by date code you'll be getting OE quality.
Old 08-15-2017   #5
yeah concerned about quality.. I don't need it but trying to 'fix' my chime, it works when it wants, only thing left is the switch as I believe it to have something to do with the circuit
Old 08-15-2017   #6
WVZR-1
Which "chime"?
Old 08-15-2017   #7
Only one in the car.. The Key, left in ignition/Seatbelt/Lights left on..
I know it works, as does the old one
I confirmed the outputs are changing coming out of the CCM. only thing I think is that there is a ground issue with the chime. but the ignition switch Must have something to do with it.
I normally would not care about the chime but my DD has auto lights and sometimes if I drive the vette to work early I have the parking lights on, but when I get to work I forget to turn them off, the chime is a nice reminder, so I would like it to work
Old 08-15-2017   #8
WVZR-1
I understand "only" but there are 2 inputs and the CHIME is SLOW, FASTER and FASTEST dependent upon what is commanded by the CCM.
Old 08-15-2017   #9
Yes, Both are intermittent.. I google search yielded a suggestion to check and resolder some pieces in the chime module..
I will do that when time allows
Old 08-15-2017   #10
WVZR-1
As inexpensive as the chime module is I believe I'd buy another and do the testing of one on the bench before fishing the one from the dash. GM# 25518745. Maybe someone has one just lying around from a previous replacement. I don't!
