Old 07-29-2017   #1
Flyman 27
Flyman 27's Avatar
Default Wanted, 1991 air horn/oem cold air box, air filter box assembly.
I am looking for a stock ZR-1 cold air box/filter assemble for my 1991 Z.
Recent purchase, present parts are warped and non-functional.
Any one want a K&N air filter?
Dan
[SIGPIC][/SIGPIC]
Cams by Pete
Old 07-29-2017   #2
lfalzarano
Default Re: Wanted, 1991 air horn/oem cold air box, air filter box assembly.
If the neck of the housing is split along the seams, that can be repaired with a strong plastic epoxy from your local parts store. You'll need some strong clams to ensure a tight seal.
Old 07-29-2017   #3
Flyman 27
Flyman 27's Avatar
I am going to revert back to the OEM paper filters. So they should fit ok, but I will look it over carefully.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 07-29-2017   #4
mhobtr
I have some extras but it will be Monday before I can get pictures to you. PM me your email address if you are interested.
mhobtr is offline   Reply With Quote
Old 07-29-2017   #5
Corvettes White
Originally Posted by lfalzarano View Post
IYou'll need some strong clams to ensure a tight seal.
Just be careful working with clams, if their shells "clamp" on to your finger...
Old 07-29-2017   #6
lfalzarano
I love that Apple autocorrect. West coast technical expertise!
Old 08-03-2017   #7
Flyman 27
Flyman 27's Avatar
Jeff from Bartlett stopped by and helped me out with my Airbox problem.
I have an aftermarket airbox with the wrong fasteners.
After a trip to ACE Hardware, all is well and working like it should.
Thank you for the support.
Dan
[SIGPIC][/SIGPIC]
Cams by Pete
