Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 07-31-2017   #21
dredgeguy
dredgeguy's Avatar
Default Re: WMD - Saturday, 29 July 2017 in Westminster, MD
Thanks to Jim for hosting. Yun was able to change out my broken antenna. Normally you can replace just the shaft and ribbon from the top but mine had to be difficult so Yun pulled the motor out from the bottom and then did the repair. He then traced down a missing connection. In the end, all good. Thanks guys!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
