Old 07-25-2017   #1
Uchunter
Default Oil cooler line replacement
Anyone know how to change the oil cooler lines on a 1991 ZR-1? I have the new couplet hoses but want to be sure I install properly.
My current hoses sprung a pin hole leak after 2500 miles.
Uchunter is offline   Reply With Quote
Old 07-26-2017   #2
BlackSheepz
Default Re: Oil cooler line replacement
Hey Uchunter,
I did this early last year. You can find my thread (both the successes and failures HERE)
http://www.zr1.net/forum/showthread.php?t=26231
Hope this helps!
--Marc
1990 ZR-1 #2530
Gone but not forgotten:
1988 Z52 4+3
1992 LT1 6 speed
BlackSheepz is offline   Reply With Quote
Old 07-26-2017   #3
Uchunter
Great --thank you BlackSheepz for the info.
Old 07-27-2017   #4
BlackSheepz
Any time. Hope my Saga helps you out.
The job really isn't that difficult, I just had some unfortunate fitment issues, and trouble getting a bolt off. Not end of the world, but a job worth while for sure.
When in doubt you can always check posts by a guy named Dynomite too, who has pretty much every solution imaginable on his Solution's page. (You'll see he comments several times on my post).
This is everything from part weights and screw sizes, to all the proper fluids and injectors, to how to get around the Photobucket $400 a year for hosting photos deal.
http://www.zr1.net/forum/showthread.php?t=16778
Let us all know how it turns out!
--Marc
1990 ZR-1 #2530
1988 Z52 4+3
1992 LT1 6 speed
Old 07-30-2017   #5
billschroeder5842
billschroeder5842's Avatar
What hoses are you replacing them with?
I've done mine twice now; the first time I used "OEM Replacements" that failed after about 250 miles then switched to Jerry's. No worries since.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 07-30-2017   #6
Uchunter
I got the part from ZR1 Specialist, since they had replaced the part last year.
Old 07-30-2017   #7
PhillipsLT5
PhillipsLT5's Avatar
Then you got a good set from Marc
