Old 06-28-2017   #1
dnobull
Default Brakes Dragging on 1993 ZR-1
After noticing that my front brakes were dragging slightly I had the pads replaced. This made the mater worse.
What other things should I replace to solve this problem.
Should I replace the calipers or have someone rebuild them?
Should I replace the brake lines?
Thanks,
Dave Noble
dnobull@gmail.com
dnobull is offline   Reply With Quote
Old 06-28-2017   #2
conesare2seconds
Default Re: Brakes Dragging on 1993 ZR-1
Try lubricating the caliper slide pins. I use high-temp grease.
Old 06-28-2017   #3
dnobull
Thank you for your reply, I did have that done when the pads were replaced. I am wondering if the Calipers need to be rebuilt or if the hoses could be breaking down internally. The problem seems to get worse as the car is driven and the rotors heat up.
Old 06-28-2017   #4
G8nightman
G8nightman's Avatar
Might be mater cylinder when was the last time you flushed your brake fluid?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-28-2017   #5
dnobull
Not yet but that will be next Thank you for your reply. I am also thinking to rebuild the calipers but need a source for the parts.
Old 06-29-2017   #6
Roadster
Roadster's Avatar
I would check and maybe replace your brake lines. They can look good from the outside, but be bad on the inside causing the fluid not to flow properly or not even flow at all. A way to check your hoses is to disconnect them and blow air through them. That will give you a good indication of the condition of them from the inside. If any are suspect, now would be a good time to replace all 4 hoses. JMO Good luck....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-29-2017   #7
S.hafsmo
S.hafsmo's Avatar
Or just open the bleed screw and squeeze the brakes. My money would be on sticking caliper pistons.
- '90 ZR-1
Old 06-29-2017   #8
USAFPILOT
USAFPILOT's Avatar
I had to flush the brake system and get rebuilt calipers, now its good; but I had the same problem. I think it was the calipers.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
Old 06-29-2017   #9
dnobull
Thanks for your reply, I think I will replace the Calipers or have them re built and do the Brake lines at the same time,
Dave Noble 1993 #180
Old 06-29-2017   #10
dnobull
Thanks for your reply that makes sense to me and will be the next thing. I might replace the brake lines at the same time
Tags
brake problems, brake solutions, brakes, dragging
