Old 06-17-2017   #1
Young1
Young1's Avatar
Default Right side O2 connector disconnect?
I am replacing my left side 02 sensor due to a persistent 44 code. I shall replace the right side one as well to ensure that the system is balanced. How do you disconnect the connector? I am all stock. The connector is between the engine mount and frame. Do I have to remove the K member? Stumped again in Florida. I did have a very successful day installing new lumbar bladders though with hog ring pliers. Yeah
Steve Young
Second Owner
SOLD
SOLD
Old 06-17-2017   #2
mike100
Default Re: Right side O2 connector disconnect?
take the k-member off...even after that, you will need to pry the lock tab with a long flat blade screwdriver while pulling on the other harness. It will pop out. Putting it back on is a little easier.
Old 06-17-2017   #3
Young1
Young1's Avatar
Thanks for the confirmation mike. I will tighten my pan bolts while in there too. Without a lift and nearing 60 years old I just don't like to do anymore than I have to.
Steve Young
Second Owner
SOLD
SOLD
Old 06-18-2017   #4
That's how I did it,plugging it back in was a nightmare,can't remember which side was easy,one side not so much. I had to take a wad of dumb dumb,that black sticky crap used to seal joints in older cars,stick the wad on the end of the screwdriver,position the plug where it needs to go and get the plug started.
Old 06-25-2017   #5
Young1
Young1's Avatar
I made an extension with weather Pack connections for the right side. No more of that nightmare!
Steve Young
Second Owner
SOLD
SOLD
