Old 06-11-2017   #1
Default Cap for fuel rail Schrader valve?
Was checking fuel pressure, looking for a stalling when idling issue, and that danged cap got away somehow!
No luck with AutoZone, btw. Where should I look to find one (some)?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-11-2017   #2
Hog
Default Re: Cap for fuel rail Schrader valve?
Used on everything GM from 1991-2012.
Description
"Fuel Rail Pressure Relief Valve Distributor-Breakerless ignition"
US$18.26
GM p/n 12570619
pic
That p/n might help you get close to the cap only?
peace
Paul
Old 06-11-2017   #3
Jagdpanzer
Jagdpanzer's Avatar
HVAC supply stores have them in brass.
Chance to revisit your old navy training in maintaining bright work.
Damn the torpedoes and pass the Brasso!
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-12-2017   #4
RussMcB
I expect to find mine the next time I pull my plenum.
I think I capped mine with an AN fitting. Can't remember if it was -4an or -6.
