#11 |
![]() Join Date: Apr 2007
Thanks Hib--Just got two--one for me and one for my son--for Christmas. I've got an older digital guage that seems fine but but I have had it a long time and I expect it to die anytime now.--Bob
#12 |
![]() Join Date: May 2010
Talk about bringing back a dead post, thanks for this Hib. I stumbled across this post while in need of a good tire gauge. It arrived today and definitely the best I've ever owned.
#13 | |
Concur Completely.........the post is NOT dead and the AutoMeter 2343 is the best tire gauge as Hib suggests......just park it in the center console ![]() ![]() And......when you are at it since you like Billet Aluminum.......along with your Billet Aluminum Belt Tensioner Pulley ![]() See All Aluminum Alternator Pulley ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-21-2017 at 06:59 PM. |
#14 |
![]() Join Date: Feb 2006
Here's a decent one - 2 AAA batteries so you can keep it alive; also has a light and
you can measure pressure in 4 different units - I use PSI ... accuracy? It matches my other gauges within one PSI at 30. https://www.amazon.com/Foval-150PSI-...val+tire+gauge YMMV ... TGF
#15 |
![]() Join Date: Dec 2003
I bought 3 of the AutoMeter 2343 gauges when this post came out. Nice looking gauge, fits my hand & seems to be accurate. It wasn't too long before the tip fell out of the first one, then the next & the last one of the three. I could put it back in & it would function. Then one fell out & it was lost. Gauge now toast, so tossed it. I was constantly twisting the tip to get the right angle to seal on the valve stem. I still have two and they work, just not handily. Fix the tip so it stays in and make the tip straight instead of an angle and it would be a better tool.
#16 | |
That sounds strange Jerry. I have three of the AutoMeter 2343s too and never had a problem with the tip. I also have the AutoMeter 2160 that I keep in the garage. I like it better and easier to use and see the pressure since it has the hose. When I bought it years ago it was $8 less, but it is still a good buy today. Image1665439132.294399.jpg Sent from my iPhone using ZR-1 Net Registry
#17 | |
I think I figured out the problem! I'm left handed and the gauges are right-handed. Does that mean they are not handicap accessible? You "righties" have it made. You should see the contortions I have to do to sign one of those credit card screens, left handed and upside down ![]() Obviously it's really not a big deal to me. a drop or 2 of Loctite would take care of the loose tip. I just need to get a round tuit! ![]()
#18 | |
Jerry, ha ha! I?m a leftie too, but I check tire pressure with my right. I?m a weird leftie or maybe not a ?real? leftie? I only eat and write with my left and everything else is right-handed. [emoji12][emoji1360]🤙🏼 Sent from my iPhone using ZR-1 Net Registry
