#71 |
![]() Join Date: Nov 2016
Mine turned out great.
![]() ![]() Throttlebody needs some new paint, though. Roadster, Your LT5 look a lot better than mine, if that's any comfort. I've got lots of darkened spots that won't clean off. If you do the re-paint, keep us posted on the cylinder cover removal.
- '90 ZR-1 Last edited by S.hafsmo; 05-09-2017 at 03:08 AM. |
#72 |
![]() Join Date: Apr 2013
#73 | |||
![]() Join Date: Mar 2014
The TB, Plenum will get painted and I may reshoot the air horn to match. The sides of the IH's are cleaning up nicely so far. Going to try the paint Cliff has suggested and see what shade it turns out to be. Quote:
Also the "Amazing Goop Automotive Contact Adhesive" suggested by Phil got delivered yesterday, so the lines will stay in there "forever"......lol ![]()
#74 |
Hey Tom . Does that amazing goop get good and hard when it cures ? I need to secure my signal lights to the ferring of my motorcycle as the screw mounts have become brittle and broke . Sorry also for hijacking your thread but I saw that goop and had to ask .
Thanks Mike Sent from my LG-H831 using ZR-1 Net Registry mobile app |
#75 |
PS . If your coming to BG I will try to remember to bring some weather proof plastic ties . Don't buy a whole pack if you just need 1 or 2 . I have a few of different sizes and will pack a few ...
#76 | ||
I cannot answer the question about the Goop, because I don't know....lol Phil would be the one to answer that for you. He has used it before... Lol, no worries about hijack, any info shared is always welcomed.... Quote:
#77 |
Some new connector info.....
Went to the auto store in the "Help" section as per Jep's suggestion about looking for two individual connectors instead of one. Well his suggestion paid off, as I found a vacuum elbow that fits perfect, IMO. They only had one, so I will try another auto store tomorrow. My main question was whether to Goop or not to Goop??? After finding this elbow and the way that it fit, I am probably not going to use the original connector. Now if I couldn't find anything, then using Goop would have been the solution... This elbow fits perfect and you have to twist it side-to-side to pull it off, that's how good of a fit it is. The one end fits on the solenoid completely and the other end holds the plenum and canister lines very tight. The only thing I might do is cut down the elbow to the lines, but I may not have to. I can almost guarantee that the plenum line (at the solenoid "original" connector) which gives so many trouble on plenum installation with coming undone could and will be a thing of the past. Although the original connector is thicker, one of the holes has become elongated and therefore would need the Goop as Phil suggested... For $2.99, you can't beat it... ![]() the new and the original....just need one more...notice the RS hole on the original, it is slightly elongated as mentioned. The line actually slides in and out of that hole. This is where the Goop would solve that problem with the original connector, if yours is like mine... ![]() here you can see one end installed onto the plenum line...see how the new elbow expands, the plenum line is not going anywhere.... ![]() connected to the solenoid, a good tight complete fit....IMO, this is the way to go..... ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 05-10-2017 at 10:29 PM. |
#78 | |
![]() Join Date: Jun 2004
Liquid Nail is a great product for what you need. ![]()
#79 |
Alrighty then . Thanks carter . Where do I buy liquid nail. I have never heard of it but if its like a silicone and gets hard to glue and hold plastic bits together then it sounds like what I need .
#80 | |
Lowes, Home depot, Walmart. You can buy in a squeeze tube or in a cylinder tube to use with the calking gun tool. just put a little on, tape over the item to hold it till the stuff sets and then it's on, big time. I swear by the stuff for mounting pictures to bricks and other tough mounting jobs. Did not mean to hi-jack........ ![]()
