Old 05-09-2017   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Throttle Body Primary Blade Wear Issue
In the process of rehabbing a high mileage (120K) TB I acquired a while back.
Found the primary throttle blade worn down significantly on one side due to side forces coming from worn actuator cam follower.
Before removing the throttle blade screws I used a Dermal with a small cut-off disk
to grind off the retainer welds on the back side so not to ruin the throttle shaft threads.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-09-2017   #2
S.hafsmo
S.hafsmo's Avatar
Default Re: Throttle Body Primary Blade Wear Issue
Is all that really worn off? Is there no notch on other side of the disk?
Remarkable. Makes sense one would have idle issues if the primary looks like that.
- '90 ZR-1
Old 05-09-2017   #3
Roadster
Roadster's Avatar
What mine looks like at almost 70,000 miles.....not sure what the substance is on the edge of the blade and around the screw. Need to do a closer inspection, but that is probably the last thing I will do, wait til after the plenum is reinstalled....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-09-2017   #4
tf95ZR1
tf95ZR1's Avatar
DAG
http://www.pontiactripower.com/shop/...ade-sealer-dag
Don't remove it!
Old 05-09-2017   #5
Jagdpanzer
Jagdpanzer's Avatar
When used, dag is applied only to the secondaries.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-10-2017   #6
S.hafsmo
S.hafsmo's Avatar
Phil,
If you've still got the throttlebody in your hands, could you take a pic of it underside, where the makers logo is?
- '90 ZR-1
Old 05-10-2017   #7
Jagdpanzer
Jagdpanzer's Avatar
Here you go
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-10-2017   #8
S.hafsmo
S.hafsmo's Avatar
Thanks!
Sent from my SM-N910F using ZR-1 Net Registry mobile app
- '90 ZR-1
Old 05-10-2017   #9
Looks like you found it!
Are you planning on replacing the throttle plate? With new one cut to original size?
Old 05-10-2017   #10
Jagdpanzer
Jagdpanzer's Avatar
Doubt if there are any OE spares around. Could fab up a 10 degree angle mandrel and turn out a few new ones on the lathe. A good project for next winter.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
