Old 05-01-2017   #21
carter200
carter200's Avatar
Default Re: TB removal and then some!!!
Originally Posted by Roadster View Post
Can't send you an email as of yet because of the forum problem.
I do have an idea for something else....
Copy that....thx...
You have a PM.....
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-01-2017   #22
Roadster
Roadster's Avatar
Originally Posted by carter200 View Post
You have a PM.....
Read and replied.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-01-2017   #23
carter200
carter200's Avatar
Back at ya.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-01-2017   #24
7-now is a good time for the little things too....such as the clips...already sanded and 0000 steel wool used and ready for paint...
[URL=http://s127.photobucket.com/user/SSROADSTER/media/94%20ZR-1/20170428_122827.jpg.html]
I would consider Carter's Billet Clips and Billet TB Cover.......
Old 05-01-2017   #25
I would consider doing a bypass of the throttle body coolant.
Old 05-01-2017   #26
I would consider..........Oh........the list is too long for this post
Tom already suggested "and then some"
Old 05-01-2017   #27
Roadster
Roadster's Avatar
Already have on the cover, will check out the clips....
Don't know if I trust myself to do the throttle body coolant
bypass...
Cliff,
You may as well post the long list, as I will probably take the Z out of service for awhile. After speaking to another member for a length of time, I am finding out that the primary blade is not to be completely closed and is supposed to be opened slightly. So it looks like that is not the source for my idle issue. So what I thought was to be was and is not!!!
Their feeling is that there is a slight vacuum leak that happens when the engine warms up. Could be a number of items. So I think I may take the Z out of service and do a plenum pull. I have to start from the beginning and go through everything to find the issue. As was pointed out, the min/air adjustment may not fix the idle issue. Feeling was the idle air stop was not touched and you didn't have the idle problem in the past, so the theory again turns to a vacuum leaks as others have pointed out. And the fact that the test Yun and others suggested to me about blocking the TB and the results being that the idle came down from being high to "normal" but did not kill the engine. And as Yun and others have said in the past, this leans towards vacuum. The other member also agrees with this theory.
And once again I appreciate everyone's input and welcome additional thoughts on the issue.
So I imagine the best way to do this is start at the pull and go from there.
To be continued........lol
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-02-2017   #28
carter200
carter200's Avatar
Tom,
You have yet another PM....
Cliff,
Thanks for the kudos
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-02-2017   #29
HAWAIIZR-1's Avatar
Default TB removal and then some!!!
Thanks for sharing all these details and nice photos Tom! I have been having some idle issues since I got this 95, but time to address it. I have this NIB TB and might as well put it to use instead of on the shelf for the last 14 years or so.
I'll add the Carter Bling Special while I'm at it and get the stainless fastener kit from Jerry. Thanks Phil for the adjustment screw tip and I'll do that while I'm at it. I'm waiting on my ported plenum and IHs from Corey so I can do this all at once. I would be better off sending the old TB to Marc to work his magic, but can't afford the down time right now without a garage. I have to do the coolant bypass too. Best wishes to get your issue squared away.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-02-2017   #30
Marc offers a very simple coolant bypass solution utilizing a bent aluminum fuel line that passes under the plenum and connects the throttle body coolant hoses to each other.
The solution I have seals the coolant passages at the injector housing (both sides) and includes a small valve to bleed the coolant system.
