Old 05-03-2017   #1
Default Re: TB removal and then some!!!
Originally Posted by Roadster View Post
Do you carry the part where the hoses connect into??? the bottom hole in the connector is the "curly" line connected to the LSF of the plenum.
No I do not have it. I can tell you that the single zip tie around the whole rubber connector will do more to create vacuum leaks than to prevent.
EDIT, text added: Zip ties can be used, but work much better if you slice out enough rubber between the pipe holes to use 2 zip-ties, 1 around each pipe. If you do that, it means you will connect/disconnect the pipe at the other end during plenum pulls, where the small spring clamp is.
I haven't personally done what I'm about to suggest, but have sure thought about it while having difficulty with that pipe & the rubber connector. Why not cut off a short section of the plastic pipe & glue it into the connector? Then get a section of vacuum hose long enough to eliminate the looped section of plastic pipe so it's not so hard to install.
Old 05-03-2017   #2
Roadster
Roadster's Avatar
Sounds like a plan, since I won't have it back together for awhile. Good suggestion.
Yun had also mentioned about gluing that end into the connector.
That connector also feels very soft, don't know if it is supposed to be that way, or is that from the heat generated in that location???
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-02-2017   #3
carter200
carter200's Avatar
You need my billet EGR plate to replace that nasty black piece you have there......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-02-2017   #4
Roadster
Roadster's Avatar
Send me a pic and info whenever you can.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-02-2017   #5
Roadster
Roadster's Avatar
Looking over Marc's papers on the TB, apparently the info mentioned in his
Throttle Body Service page points more to a vacuum leak for me, rather than the TB itself. There have also been other members who have stated the same thing.
And also learned something else on this read, and that is, that Dag is not used on the primary throttle blade.
Just for clarification, the sentence below was JMO, was not read anywhere...
Of course the leak can be so minor and only occur when the engine goes in Closed Loop.
I think a gasket change is in order and a complete check of every line.
I also need to find a 1/4" drive T-40 or a thinner 3/8" drive T-40 socket when torqueing down the plenum bolts. There are 2 bolts, 1 on each side of the plenum between the runners, that is very tight to get in there. I had to use a 6mm Allen key and a spark plug socket to go over the Allen key for leverage with a short extension and the 3/8" ratchet to break 1 of those bolts loose.
So if anyone knows where I can get a thin walled T-40, it would be appreciated.
Found an extended Torx set in 3/8" drive that will work perfect....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-03-2017   #6
"Of course the leak can be so minor and only occur when the engine goes in Closed Loop."
This does not happen. A vacuum leak is a vacuum leak. It doesn't care about open or closed loop. There's nothing that happens in closed loop that would create a vacuum leak if there wasn't one there already.
Old 05-03-2017   #7
carter200
carter200's Avatar
You have an email with pic and price
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-03-2017   #8
Roadster
Roadster's Avatar
Thank you sir, will check it out today....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-08-2017   #9
S.hafsmo
S.hafsmo's Avatar
Remarkably clean coolant passage. I assume you've installed the Carter bling on the TB? How did it look under the old TB cover?
- '90 ZR-1
Old 05-08-2017   #10
carter200
carter200's Avatar
How did yours turn out?
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
