Old 04-09-2017   #1
Default Clutch master to slave hydraulic line??
I need to replace the hydraulic line between the master and slave cylinders on my 90 ZR-1. I tried several to no avail.
I imagine too that a competent hydraulic repair shop would be able to make one, OR maybe I could (with the right parts and tools of course).
Of course, I'd prefer new, AND braided too would be nice. (I tried Jerry's Gaskets web page, but if he's got 'em, his search engine can't find 'em, apparently...)
Any recommendations???
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-09-2017   #2
KPW
KPW's Avatar
Default Re: Clutch master to slave hydraulic line??
I bought one for the 91 at Corvette Central, new and braided.
Just looked and here is what they have for 90. Not sure if this is LT5 specific?
http://www.parts123.com/corvettecent...50f&ukey=13194
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 04-09-2017   #3
Well, that was quick! Thanks!!
90 #1202
Sans secondaries
Old 04-09-2017   #4
HAWAIIZR-1's Avatar
Hey P,
I'm at work now, but I'll send you the part number tonight for the braided one you're looking for. I just bought one. Someone will probably beat me to it.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-10-2017   #5
HAWAIIZR-1's Avatar
Hey P,
As promised. Part #CH9196. You can it get from a few places:
http://www.cssbinc.com/corvette1991-96clutchhose.aspx
http://m.ebay.com/itm/121100757521?_mwBanner=1
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-10-2017   #6
Thumbs up Re: Clutch master to slave hydraulic line??
Hey P,
Great info! I thank you, as do many others here I'm sure!
90 #1202
Sans secondaries
Old 04-10-2017   #7
Hey P,
I think this is one more case where there were changes between 1990 and 1991. 1991 appears to be a SS Braided hose with swedged end fittings and 1990 appears to be a combination two steel pipes and short length rubber hose in between
If this SS Braided hose works on your 1990 Paul......post up
Just found out the Full Power Key Switch may be another change between 1990 and 1991. Waiting on that verification for the moment as Kevin and I both successfully refurbished our 1990 Full Power Key Switches which refurbishment does not necessarily apply to 1991 and later
I may have to modify/upgrade..........Differences between 90', 91' and 95' ZR-1s and Engines
Old 04-10-2017   #8
Well, many thanks for all the leads! I've ear-marked them all for reference.
In the mean time, I might have located one from Summit Racing - which is 1/3 the cost (is $44.xx shipped) of some of these. But, if it doesn't fit, then I won't hesitate to "pull the trigger" for one of these recommendations!
Again, mine is a 1990 - not sure what the difference might be, tho the Dorman slave has the bleeder on the bottom (hallelujah!).
I will "post up" with my findings when parts arrive.
Paul.
90 #1202
Sans secondaries
Old 04-10-2017   #9
2ljd
Corvette Brakes makes one for the 89-90...
http://www.cssbinc.com/clutch-hose-1...t10147949.aspx
2ljd is offline   Reply With Quote
Old 04-10-2017   #10
HAWAIIZR-1's Avatar
You're welcome P! When I had my 90 I upgraded both the line and clutch slave cylinder to later model per both the Doc and Jim J for the bleed purpose. I think both have to be done together.
http://www.zfdoc.com/clutch_hydraulic.htm
At that time I had the GM line. If I had another 90 I would upgrade it too.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
