Old 03-15-2017   #11
Hib Halverson
Default Re: Oil Usage
Originally Posted by TealZR1 View Post
Yes, like most of us foot is mashed much of the time for the fun of it. The car runs 10 W 30 synthetic. At this point of it's life. Should I run 10W-40 or 20 W 50? Thanks for your help!
"Foot mashed much of the time" means to me that you run the engine hard. If that's the case, with that mileage, I wouldn't worry about 1000 miles per quart.
I'd stick with 10W30 unless you experience sustained high oil temperatures, say...above 250°F. If that's the case, go to a 10W40.
I've had great luck with Gibbs Driven DT40. It's actually a 5W40 and, nowadays, I use it in all my Corvettes.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-16-2017   #12
TealZR1
Originally Posted by efnfast View Post
It seems like the first quart goes away very quickly. Leave it down a quart, as long as your not road racing, you should be ok. Don't forget, it has 12 quarts in it.
Thanks Efn, I have a question. If I let the first quart go away and not refill it. Would the remaining oil dissipate also? What happens when that first quart burns off and where does it go? Thanks
TealZR1 is offline   Reply With Quote
Old 03-16-2017   #13
A1990
A1990's Avatar
+1 for Gibbs Driven
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 03-17-2017   #14
efnfast
Seems oil consumption drops dramaticaly once the level drops a little. I've heard it referd to as windage from the crank.
My 90 seems to lose a quart real fast, then very little after that. As mentioned earlier, the 90's don't have exhaust valve guide seals (mine will shortly), so the oil goes out the tail pipes. Of course at high rpm, you don't even notice in the exhaust.
One quart out off 12 is only a 8% loss of volume. one quart out of 5 (regular engine) is a 20% loss of oil. -Steve
Old 03-17-2017   #15
Jagdpanzer
Jagdpanzer's Avatar
When to the full mark the oil level is right up against the windage tray. So if the oil level is a little over the crank catches it and the overage mostly goes out through the pcv system in a hundred miles or so. As mentioned you can run the oil level down a quart without any risk to the engine however, the low oil level light may become a nag sooner due to its sensor being located more or less at the same position as the windage tray. Unfortunately it's not easy to relocate the sensor a little lower.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-17-2017   #16
TealZR1
When I inspected my PCV valves recently I did notice what appeared to be more oil than should be on the valves - my best guess. Hopefully this post helped others like newer ZR1 owners since this appears to be a common issue. Interesting to learn no valve guide seals were installed. My next project I guess down the road so will be back in touch on how to do this project.
