Old 01-23-2017   #1
koshe2
Default 91 Engine Noise
I just bought a 91 ZR1 with 115K miles. 6 speed Has this knock when its cold, at engine speed. It goes away for the the most part when its warm. Does not rattle at idle, but seems to start at 2000 RPM under load. Sounds like a lifter, Injectors have been replaced at one time.
I live near St Paul MN and would like to have this checked out. I am not super worried as it calms down when warmed up. Oil pressure looks just fine.
Where do I start? Suggestions??
Not sure what oil is in it. Not sure what to uses. 10-30 mobile 1??
I am new to this forum...
koshe2 is offline   Reply With Quote
Old 01-23-2017   #2
Default Re: 91 Engine Noise
knock or tick? Did you try pulling plug wires to see if there is one that does not change the issue when a wire is pulled?
Old 01-23-2017   #3
billschroeder5842
billschroeder5842's Avatar
Welcome to ZR1 Land!
Is there any way you could post a video w/sound?
Sounds are tough to diagnose over the web as one mans Knock is another mans clunk.
Also, if the sound goes away when warm, does it make sense to let the engine warm up a bit longer before putting it "under load?" Our LT5s like to be warmed up and fully lubricated. The fact that you mention that the sounds goes away when warm is your biggest clue that you may be driving the car before it's ready.
Minnesota is WAY cold and your engine is probably needs a few moments.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 01-23-2017   #4
could be a stuck tensioner or chains
Old 01-23-2017   #5
Hib Halverson
As suggested earlier, it's hard to diagnose noises via the I'net.
They way you describe it in the OP, I'd say it's not any chain tensioner issue.
Could be cold piston knock which is common with the LT5. Cold piston knock is really not a "knock" like a "rod knock" it's more like a "fluttering" lifter noise at low rpm under load which goes away when the engine warms to operating temperature.
I guess we're going to need either a better description of the noise or an audio file to offer more information.
Old 01-23-2017   #6
32valvesftw
Carefully use a long screwdriver like a stethoscope put your ear to the handle you will be able to get a good idea of what section of the engine its coming from. Also have you done a recent oil change, if not maybe do so and look for metal dust or bits in the oil. Noises like that time to find.
Old 01-23-2017   #7
Welcome, All I can say is it takes a bit of time to get use to some of the unique sounds of the LT5.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-23-2017   #8
ssrszz4
Sometimes mine reminds me of a jet engine when I get on it.
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
Old 01-25-2017   #9
I was going to suggest Piston Slap but then koshe2 said "seems to start at 2000 RPM under load"
By the time you put on a load at 2000 rpm Piston Slap usually has disappeared
Old 01-25-2017   #10
koshe2
Is that an immediate concern?? I am hearing that its not all that unusual
