The Worst Mouse Damage Ever and the guy has not even looked under the Plenum. In this case I would be scared to look under the Plenum.
There are a lot of items the mice have chewed on that will prolly still function perfectly but look bad. I have never seen so many different items the mice have chewed on (and the Plenum has yet to be removed) as this case. Just a Warning.....it can get BAD ![]() The Worst Mouse Damage TIPS
![]() Join Date: Jan 2012
Dang ... I hate mice. I don't know why the like to chew up wires.
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 ![]() |
In this case they chewed sensors, Coolant hoses, windshield wiper hose. But....... another guy responded describing mice INSIDE the car which is even worse.
![]() Join Date: Feb 2012
They use Mutton Tallow in the process of putting the insulation on the wires.
![]() Join Date: Feb 2011
Use moth balls that come in packets and stuff them between the intake runners. Count the number that you deploy because you don't want to burn one you forgot to pull out before driving.
It also repels snakes if you deploy them near the door openings. Sent from my iPhone using ZR-1 Net Registry |
#6 | |
![]() Join Date: Sep 2008
I never knew that, but it certainly explains the attraction and gnawing. As for the earlier post; If I were a mouse I would not screw with Boris either! Maybe I could even learn to tolerate paw prints! You go Boris! (Actually, Boris appeared in a similar thread in Corvette Forum ) ![]() Marty Last edited by DRM500RUBYZR-1; 01-17-2017 at 08:38 AM. |
Yikes
![]() Join Date: Aug 2006
I hope Boris had been de-clawed. I had a cat that used my freshly painted 1973 Challenger as a slide and I would have preferred to replace coolant hoses and electrical wires...
![]() Join Date: Sep 2012
I store 6 Corvettes and I put Irish Spring soap under the seats, on the floor and on the engine block and never had any problem with mice. I do the same in my bus and that has been stored for almost 6 years.
Nelson
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
#10 | |
