A few days ago I brought my 1990 ZR-1 in for an oil change and specified to the mechanic that I wanted Mobil 1 High Mileage oil. He replaced the 8.5 quarts and gave me a half quart to bring home. When I got home, I noticed that he put in 5w-30 weight oil instead of the 10W-30 that the car calls for. Is this a big deal? It is synthetic and has some 10W-30 from the last oil remaining that doesn't drain out. Any thoughts?
The car only has 11,000 miles on it. |
In New York it is getting cold so lighter oil is better this time of year.
#3 | |
![]() Join Date: Dec 2014
I just drove around for two hours and my temps are much lower than summertime...coolant 75-85°C I use Amsoil 10w-40 and Mobil1 15w-50 in each car, they are ready for oil changes soon. |
![]() Join Date: Oct 2004
I don't know that it's that easy to just let the facility "off the hook" - I've no "first hand" but I'd think there's little argument for the change from 10/30 product to the 5/30 product for a car that isn't going to see "everyday" use. Even then I'd maybe think very hard before the change.
Maybe you make the facility aware of what was done and negotiate a change to the 10/30 in the spring. A '90 MY with 11K should certainly still have the OE oil fill cap that specifically states 10/30 and I'd have thought anyone I do business with would ask first. I've a 3800 SSEi SC and from time to time I use a quick-serve facility for the oil change and they go out of their way to mention they've used the 10/30 spec on the oil cap. Until very recently they used bottled product but they've added 10/30 bulk and now they ask which! |
Thanks guys, I appreciate the input; I called Vette Doctors over in Amityville and they said pretty much what you guys advise, winter is coming, and with the lighter oil, it really wouldn't hurt the engine. I did let the facility know that they put in the wrong weight oil and they couldn't care less. I was using them for all three of my cars and now they blew it.
Last edited by soslow; 10-14-2016 at 11:44 AM. Reason: adding additonal information |
#6 | |
![]() Join Date: Mar 2014
Our '03 Vibe now is @ 170,000 miles, and still runs strong. Use oil, yes it does, more probably leaks then burning. Add up to a 1/2 quart from time-to-time. And I just use conventional oil in that car. My point is no matter what oil you use, you can get longevity from any engine when properly maintained, which means doing PM's and having the correct fluids. That being said, if that shop put in 20W-50, or 15W-50, or straight 30 or 40W, then that would be a cause for you to be upset. JMO....... Just another side note, way back when oils were a lot different and didn't have quite the viscosity ranges that they have today. Even on cold morning with a slightly heavier "weight" oil, sure it may have taken a few extra seconds to start the engine on a cold morning, but you just let the engine warm up a little bit longer, of course today, it's totally different. You would have to completely abuse your engine in some way, shape, or form, to verify that the difference between a 5W & 10W oil for cold weather starts is damaging your engine in colder climates.....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-14-2016 at 12:04 PM. |
I think that I am more concerned with the issue that the owners manual clearly states "For the LT5 engine use only 10w-30 weight oil" an it is also printed on the oil filler cap and I specifically told the shop to use it. But, alas, they used 5w-30 instead and didn't tell me. I didn't want to be neurotic about it, as the experts at Vette Doctors said it would be OK, but I had to be forced to do the research after the fact to put my mind at ease after the deed was done. Reading that specific sentence in the manual made me concerned, I felt for good reason as I am not a mechanic.
Sent from my iPad using ZR-1 Net Registry |
#8 | |
Yes, I understand your concern, and rightfully so.....but also understand that oil technology has jumped leaps and bounds since the 90's and before.....I do not have my owners manual in front of me, but sometimes, (not saying the ZR-1 manual does), the oil recommendation will cover a more slightly given range according to your climate conditions where you live. I now use Mobil 1 10W-40 High Mileage in mine. Went on recommendations of the ZR-1 experts here on the forum, which there are quite a few.... ![]() I am not concerned about cold weather starting at all. Mine is garaged, and regardless of what time of year it is, when I start the Z, I back out and let it warm up so that the coolant reaches 200 degrees and above. In doing that the oil temp also gets near the correct operating temps that it should be for wide open throttle operation if need be.....this way I avoid jumping on the highway and maybe using more throttle than necessary on a cold engine to get into the flow of traffic. Overkill.....probably, but that's what I do. You will do more damage to your engine using more throttle (then need be) when cold and not fully at operating temps, than being concerned about your oil weight (viscosity)difference between a 5W & 10W oil. Do not take this the wrong way, you did the right thing in asking questions and doing your research. At my age I still do research ![]() Enjoy your Z, always check your fluids, tighten up all of the "screw" connections on the engine every so often, (vibration=loose screws) which can turn into annoying leaks..(of different kinds). Get into the habit of doing PM's (Preventative Maintenance) on a periodic basis, and you will have many enjoyable years of ownership..... ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-15-2016 at 02:57 PM. |
![]() Join Date: Nov 2007
Hard to think of another topic hashed more and seeded with as much sales hype and in some cases misinformation as oil. Chemical engineering ain't my long suit: I have lots of company I'm sure.
So! What's the best answer? Are bought and paid for studies honest? What lubrication requirements are unique specifically to the LT5 that might frame the decision/choices? Far beit from me to presume ro offer expert opinion or recommendations based personal expertise. But, it is possible, I think, to identify some of the most important things which distinguish the motor from some of those others with their pushrods and roller tappets, and limited rpm range, for example, The things that jump out at me and other students of the LT5's characteristics is: flat tappets, 7000+ rpm redline, long and numerous chains, smallish cam sprockets, viscosity srability of synthetic oils over extreme temperature change, the chemical makeup (features) of oils specifications at the time the motor was built. All this considered as well as recommendations from those knowledgeable people I and others trust, is how I came to settle on Amsoil 10W-40 recommended by Marc Haibeck. I'm more WARRIOR than WAXER. 7000+ rpm reached ea. outing is "normal". In it's 9th season now, and she runs like a fine watch. So far so good! I'll stick with what is working in the knowledge unique LT5 requirements are specifically being met...at least so it seems! |
#10 |
I greatly respect your experienced opinion and the expertise of Marc Haibeck so I think you guys have me convinced. I'll consider my Mobil1 High Mileage 5w-30 oil change an engine flush for the winter, where I don't use the Z much anyway and in the spring I will follow your recommendation with the Amsoil 10w-40 from then on. Thanks.
