08-03-2016 | #21 |
Re: ECM And Ignition Module Availability/ replacement
I work for a company, that designs and produces printed circuit boards. After seeing that picture of the DIS module made me think. Could it be redesigned to modern specs? I know nothing about electronics, I'm just the inventory manager. But I honestly think it could made new. But just as someone said, it would be expensive......Maybe a group fund or something to pay for the design and production / testing? We do all of our design, engineering, production and testing in house. As far as I know we are one of the few places in the country that makes certain embedded, and printed boards.
Lol I'm not hocking where I work, but here is our website............ http://www.emacinc.com/ Last edited by rush91; 08-03-2016 at 05:39 PM. |
08-03-2016 | #22 |
Hi Jerry,
What Aftermarket systems are good for use with the LT5? I assume the Megasquirt will work with an external trigger wheel. I am curious of all the options currently
08-04-2016 | #23 | |
Others here can answer "all the options currently" question better than I can. I think all aftermarket units will probably require a trigger wheel different than the reluctor wheel on the LT5 crank.
08-04-2016 | #24 |
Fair enough.. I knew it would require an external trigger wheel
08-04-2016 | #25 |
08-04-2016 | #26 | |
Still using stock Ignition module? Or is it built in to the mega squirt ECM What are the other issues? Sent from my iPhone using ZR-1 Net Registry
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 08-04-2016 at 01:25 PM. |
08-04-2016 | #27 | |
Graham. |
08-04-2016 | #28 |
10-06-2016 | #29 |
So this still is a major concern.. Do we know how many Ignition Modules have failed? If mine fails, my car would become a big paper weight. If there are other avenues for ignition they need to be explored..
10-06-2016 | #30 | |
There will probably be a work around with other factory parts in the future, but not until there is zero availability of the original modules. |
