Old 08-22-2016   #1
Greatlandguy
Default LT5 Smoking on Startup
I have a 1991 ZR-1 with the first generation (375 HP) LT5 engine with 36,000 miles on it. I noticed now that upon starting, a significant amount of bluish white smoke emits from both tailpipes for a few seconds and then dissipates. It is not water vapor. No smoke has been observed when driving, though. Associated with this issue is a significant increase in oil usage, I calculated 1/2 quart per 600 miles.
Advice has been given that this could be worn valve guides or valve seals allowing oil into combustion chambers. Any thoughts on cause or diagnostics that can guide me to proper repair would be greatly appreciated!
Greatlandguy is offline   Reply With Quote
Old 08-22-2016   #2
Default Re: LT5 Smoking on Startup
low miles but prob the valve seals and guides as stated since you stated the oil consumption as well. This is something normally confirmed after the tear down. GC
Old 08-22-2016   #3
I would make sure the PCV system is working. Any oil in the corrugated intake/Air Horn?
Old 08-22-2016   #4
Greatlandguy
Thanks for the help, gentlemen. I will check the corrugated air intake and air horn for oil ASAP.
Old 08-22-2016   #5
Marc Haibeck on oil consumption
Seems you are average on oil consumption if you are driving it fairly hard. If you are just cruising then maybe a bit much on oil consumption. As an example, I just drove 2,000+ miles with 95' and did not use any oil. there was about 4 tablespoons of oil accumulated in my oil catch can
Old 08-22-2016   #6
Its normal for an early LT5. They didn't have exhaust oil seals.
Old 08-22-2016   #7
cvette98pacecar
Old 08-23-2016   #8
Dime
Just the 90s if I'm not mistaken.
Dime is offline   Reply With Quote
Old 08-23-2016   #9
Correct MY 90 only
Old 08-23-2016   #10
32valvesftw
The OP did not state how long he has owned the car, so this may be a problem he inherited from the previous owner or a new problem that just surfaced. It would be good to know. I think he should do a compression leak down test. Checking the PCV system is good start IMHO, you might get lucky and avoid the leak down test.
