Old 06-25-2016   #11
riselly1
Default Re: Got a few codes.
I'm still on the works trying to get an obd1 scanner. My local auto parts say they no longer scan vehicles. ?? 🤔
Anyway, I cleaned the IAC, it had some gunk on it but the bad news is the seal came apart when I sprayed it. It just desintegrated, how bad do you think that's gonna mess me up??
Also I unplugged the brake booster to rule out a diaphragm leak, but the engines behaves the same, so.... NEXT !
riselly1 is offline   Reply With Quote
Old 06-26-2016   #12
Racinfan83
Sounds like you have vacuum leak/s to me. MAP sensor connection was my worst one...
Old 07-06-2016   #13
riselly1
Hey ladies, taking the plenum off tomorrow morning. Did a vacuum test and it doesn't hold ****. Once warmed it's not as bad, som I'm thinking something is expanding and maybe sealing off the leak??
Break booster and secondary pump hold vacuum like champs. I will follow some write up I found here at the registry.
Any words of wisdom?
Old 07-07-2016   #14
Before pulling the plenum, pull the BATT - cable and then open the ECM. Pop the prom and then re-seat it until the tabs on either end snap properly and snugly.
See what happens.
If the secondaries are not holding vacuum, that needs to be addressed.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-07-2016   #15
mike100
There are 3 or 4 common places under plenum where vacuum leaks and also the map sensor hose is a common failure that causes erratic driveability (many times with no codes associated with it).
Will it idle below 1000 rpm when it is warmed up?
Old 07-08-2016   #16
riselly1
Tried the battery with no luck and no codes either. Plenum came off !!
First order of business; I found 4 leaks , sweated like a pig and got a sore back. Leaks are as follow:
1) 2 x secondary vacuum canisters; are there guys supposed to hold any vacuum at all, b/c air just whistles right out and I can see a plate moving back and forth as I applied vacuum on both?
2) the T section between the check valve and reservoir; funny thing is it holds vacuum coming from the side plenum line, but when i tried the line coming form the secondary pump it looses all vacuum in 10 s. ** secondary reservoir holds perfect vacuum.
3) driver's side line going into the secondary vacuum solenoid. it just whistles and i loose vacuum in 10s. the right side line is good.
I included a pic highlighting the leaks in blue. Check it out and let me know if something doesn't make sense before I start hunting for parts.
File Type: png Screen Shot 2016-07-08 at 3.18.06 AM.png (785.9 KB, 25 views)
Old 07-08-2016   #17
Top Toy
Top Toy's Avatar
Now would be a great time to get rid of your secondaries. Very common mod for LT5's. Eliminates a lot of the headaches you're wrestling with with no loss of driveability. Lots of info on this forum re how to do it.
Sent from my XT1254 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
Old 07-08-2016   #18
I've been kicking around this idea and if I could find a stock cube non-ported car to drive before I do I probably would.
Old 07-09-2016   #19
Just do it Kevin and have Dom retune it for ya it. Worked great for me
Old 07-27-2016   #20
riselly1
Hey guys finally had the time to put everything back this morning. Changed both secondarie canisters and my check valve wasn't working either. The entire system holds 15+ of vacuum now 👏👏👏
Problem: after say 30s-1min of running white smoke/fog comes from under plenum on the passenger side only. She also did it before taking plenum off. I don't like smoke so I didn't play with it anymore, any suggestions???
I also noticed viscous oil deposits on the long piece where the injector housing connects to the block.
