#11 |
![]() Join Date: Jan 2010
you can have the lower ET and faster MPH and still lose a heads up drag race
if the other guy leaves 1st you've gotta catch him and go quicker by at least that amount + again, the clock doesn't start until the beam's broken RT is the time between the green going on and the the beam being broken by the car moving. roll out, staging deep or shallow plays into it a little but means little to the average drag racer who just wants to see how quick/fast his car is. OBTW: bracket racing ain't real racin' |
#12 |
Despite the glaring inaccuracy's I'm just glad for some exposure.
#13 |
![]() Join Date: Feb 2013
Thanks. Guess I learned something. I have never been to a drag strip. Actually I'm glad to hear because I would like to get a time on my car but at my age and lack of experience I know my reaction time would be lame. However my bucket list is to put my z on a track like the NCM motor sports track. I drove there last year but elected not to run due to one of my wheels is slightly bent. But I will return!!
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
#14 |
![]() Join Date: Mar 2013
As it has been said, RT has nothing to do with your ET, only how to beat or lose to the other guy.
stock 90 ZR-1 with good driver (many laps to learn the car) will run 12.9 to 12.8 all day long. But you need a lot of seat time, 25 to 30 laps to get it down just right. My best bone stock was 12.82 at 112, with 18 psi in the rear, 60 psi in the front, 1/4 tank of gas, start out at 1000 to 1100 rpm and "feel it" out of the gates and feed it in hard as you go. just a little "bog" and off you go. need to shift as fast as you can in the 1 to 2 with a lift off the gas (no power shift) as the stock tires will not hold it unless the track is well prepped. than the 2 to 3 shift is a power shift, run In 3ed to the end do not pull 4th. you will be running right at about 6500 it the end. its a ride you will never forget when you get it all correct! Dean Nelson |
#15 |
![]() Join Date: Aug 2008
My 90 is pretty stock and it ran in the high 12's with a bad 60ft time so with a perfect launch you might make it into the high 12.8.
#16 |
nice reaction time!!!
#17 |
#18 |
![]() Join Date: Mar 2007
my 90 ran 12.88 @112.68 w/138K on the clock, original cats and a Corsa; difference between A 13.4 and high 12s is launching at 3-3.5K
#19 | |
Not as quick as I used to be (or think I was) |
#20 |
How is the MPH calculated? Mathematical or a speed trap at the finish line? I have no drag car experience but run a boat in the 10 second class. My speed trap is 132 ft. from the finish line. Sometimes it`s 66 ft..
