Old 02-05-2016   #1
Johnny5
Default Headlight Noise/knocking
So i went to start up the Z to let it run for a little since I haven't driven it in 3 months and when I turn the headlights on than off I hear a knocking coming from the pop up headlights. The headlights turn on and off and rotate properly but when they close I hear a knocking sound? Anyone have this issue or know what the problem is?
Johnny5 is offline   Reply With Quote
Old 02-05-2016   #2
efnfast
Default Re: Headlight Noise/knocking
Sounds like the gears are on the way out.
Old 02-05-2016   #3
Jagdpanzer
Jagdpanzer's Avatar
Common C4 issue. Time to replace the 3 plactic bushing cushions in the hub of big drive gear. Plenty of how to articles on the Internet.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-05-2016   #4
G8nightman
G8nightman's Avatar
Gears for sure I replaced mine with updated metal ones.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 02-08-2016   #5
Johnny5
Thanks for tbe advice brothers
Old 02-09-2016   #6
lisounds
lisounds's Avatar
Corvette Headlight Motor Gear Kit, 1988-1996
http://www.ecklerscorvette.com/corve...1988-1996.html
lisounds is offline   Reply With Quote
Old 02-12-2016   #7
Johnny5
So i read on corvette forums, guy had same issue where the headlights rotated fine but made noise and everyone said if it flips open and closed find it was not gears but the metal balls/bearing that need to be replaced, you can find em from ford window motors. When the salt clears i will take them apart and imvestigate.
Old 02-12-2016   #8
Johnny5
Hey LI Sounds, i bought my gf that headunit for V Day so i will recommend your shop for install.
Old 02-12-2016   #9
dredgeguy
dredgeguy's Avatar
Like Phil said, it is the 3 plastic bushings that turn to dust. Three needed per side and you are correct, they are labeled for Ford window assembly in the specialty section of Advance Auto. Costs about $6 dollars. This is all you will need.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 02-12-2016   #10
G8nightman
G8nightman's Avatar
You will have to open it and have it all apart anyway. I would do the gears instead of doing it twice just swap the gears as well just 50 bucks. What happens if you take it apart and the gears are shot as well?
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
