Old 01-26-2016   #21
Karl
Karl's Avatar
Default Re: Which headers should I buy, bang for the buck?
Originally Posted by Kevin View Post
do I even want to know what the jeal copies run?
I paid under $500 new for mine. With shipping it was about ~$520
Old 01-26-2016   #22
MuRCieLaGo
Where did you get it?
Thanks for the input guys, as I can see the OBX doesn't have such a bad reputation.
Paul, you think you would still be able to build that custom bracket if I buy an OBX?
Old 01-26-2016   #23
efnfast
Bang for the buck. OBX.
Some others may make a little more power.
I think the fitment issues are pretty much the same for all.
OBX made in China.
Rip off of Stainless Works.
I have the OBX and had them ceramic coated.
If the OBX had been just a little cheaper I would have gone for something made in the states. They were a lot cheaper.
Old 01-26-2016   #24
efnfast
Along with Paul's bracket, you'll also need an o2 extension.
Old 01-26-2016   #25
Been very happy with my SW long tubes coated and installed almost 10 years ago, photo from last year, they have held up well.
As you can see cats work just fine with LT headers. No issues with fit.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-26-2016   #26
If I'm not mistaken, some of my brackets are being used on some OBX headers. Tell me this: how thick are the flange (s) on the individual exhaust tubes? I'll need to know that in order to answer that for sure.
Old 01-26-2016   #27
Before I bought my OBX, I had an opportunity to look at Corsa and OBX headers side by side before being installed in cars. Primary tube, angle of bends, stacking were all identical. Only difference was OBX primaries are about 4-5" shorter allowing OBX to add a pair of bullet cat looking pieces most likely so that, if elected, purchaser can easily add a pair of cats. This also moves O2 sensor bungs negating a need to extend O2 sensor connectors. There was no quality difference. Shorter primaries may theoretically reduce hp gain but I'm not convinced this to be a serious compromise.
Old 01-26-2016   #28
under 500$ for corries?
Old 01-27-2016   #29
Karl
Karl's Avatar
Paul your dip stick header bracket works and fits perfectly on my OBX headers.
Old 01-27-2016   #30
Karl
Karl's Avatar
No, OBX headers.
