#21 | |
Plan A: Try to put a conventional drain plug there (with a washer). Plan B: Tap bigger threads with a bigger drain plug. Plan C: If it is cracked, I'll have a plate welded under the oil cooler. Plan D: If the oil cooler really is broken, alright I'll look for a used one. But thanks Dynomite I really appreciate your help! |
#22 | |
If it is originally an NPT or Pipe thread it would be relatively easy to find a slightly larger straight thread for which you can drill and tap and then use a bonded washer like for the Oil Pan Drain Plug. You would then have a Real and somewhat Unique Oil Cooler Drain Plug ![]() Others would then consider that conversion for Draining/Changing Oil Cooler Oil ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-01-2015 at 12:27 AM. |
#23 | |
![]() Join Date: Oct 2004
Is it magnetic? If it can be determined that it is an NPT product maybe just changing the material used and an appropriate sealer is a more desired repair. Is it maybe NPS? Is it maybe an ISO 7-1 pipe? Is it maybe Metric? It's a "once and done" thing. Identifying the removed plug I'd think critical - no guessing - use thread pitch gage and appropriate measuring devices. Last edited by WVZR-1; 12-01-2015 at 04:10 AM. |
#24 | |
But if you DO remove the radiator....time to inspect and clean the trash from both the radiator and Oil Cooler...AND....AC Condenser.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-01-2015 at 05:22 AM. |
#25 |
I would be worried if you threaded the drain plug all the way in that it will get circulated through the motor and cause a clog somewhere else. Which could cause oil starvation.
Take the cooler out and see if you can get the drain plug to come out of the cooler altogether. Plus with it out, you can make a better repair to it. Vacuum leaks suck. It seems like everytime I fix mine they come back during the winter time. Not sure what causes that to happen. If you become a member you can actually get the Heart of the Beast magazine. There was a good article about vacuum leaks by Marc Haibeck. |
#26 | |||
I removed everything but the AC Condenser. It was really dirty there, so I cleaned everything. Quote:
Kinda sucks to break something while trying to fix a vacuum leak... That's part of the game I guess! Thanks everyone! |
#27 |
Oil cooler is in place now, started the car this morning. Everything is fine now. The most expensive in that story was the coolant flush. Wasn't ready to pay 94$ for some Prestone.
That vacuum leak will wait now. Enough love given to the car at the moment, time to go back on the RX-7. Much easier. |
#28 |
hi guys...
havent posted here in months..logged on a few times recently..i got my 94 back in march of '14 ..as the snows melted i realized it had the dreaded constantrunning vacuum pump peterout at 5000 rpm symptoms of leaky vacuum/failing secondaries..immediate solution was buy myself a harley in june of 14 for my wife's birthday..sorry for rambling.. point being here's what i finally did after 11,000 miles on the harley and maybe a thousand on the vette...and the advent of cold weather here in poughkeepsie..i called my local chevy dealer , healey chevrolet..told the service manager i needed an oil change( i had the 3 gallons of amsoil and the wix filter laying around and they agreed to use it),told him about the vacuum leak.. he said they had two techs who had been on vetts for ever..i breathed deep, gave them the car, they fixed it for $600, the vacuum pump runs for 1/2 second and it pulls like hades.. just saying theres that option..enjoy. and good luck..very good luck on tigwelding and tapping the oily threads on the aluminum pan..you could try lampwick on the plug.. Last edited by weldbead; 12-03-2015 at 12:50 AM. |
#29 | |||
Plugging the Oil Cooler Drain Plug Permanently (90'-92'-93').
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-03-2015 at 05:57 AM. |
#30 |
The shop welded the old drain plug in the hole with silver, $40 later.
I used the conventional pre-mixed green Prestone coolant. ![]() |
