#11 | |
I'm not interested at all by the regular C4 shocks option. But like We_Gone said, the might only be because one of both shocks is from a regular C4 and the other one from a ZR-1 (Bilstein?). I tried to do some research on the car, the only thing I could retrieve from Autocheck is that the car comes from Ohio 1996-2006, was collecting dust from 2007-2013 and is in Canada since then. Price won't be lowered by much now, maybe I can go to high 12k but that's about it. I'm surprised you also have that problem of your rear wheels not being level. I'll do some search on that, I thought it was a very local issue. Thanks for your answers We_Gone, it's always nice to get quick, detailed answers to my questions. |
#12 |
![]() Join Date: Dec 2014
$13k seems like a low price considering the info given.
Owning my ZR-1 for just a short time, I've compiled a list of a dozen fixes and mods to be done this winter... and my car is what I'd consider nearly perfect for a 25yr old. These are fantastic cars, with exceptional community & forum support. I hope this one's within your comfort zone, or you find an even better one! |
#13 |
![]() Join Date: Jul 2007
Also, for the issues listed, Are you willing to be the one to do the work or will you need someone to do it for you? That in my opinion is key..
From the items you listed, I think you can push for a better price a bit and you may get a nice deal. how does the car look overall? I bought my 1990 with 60K miles in 2007. It needed quite the work, but I do as much as I can on my own.. it turned out quite nice.. Someone that saw a rough picture said it was a flood car, I have not seen any signs of that other than it was really rough.. But the driven train is solid and I too had a SRC light which turned out to be a loose shock. I have since replaced the shocks (did coilovers). I have seen cars with stock spring not sit perfect in the back, both my 90 and my previous 89 were this way.. If you like the car, the engine is solid (outside of the Alt) Everything else is purely C4.. If I was looking that would eb the car I would look for.. needs a small bit of work but priced for some of us that cannot afford the completely pristine NCRS ready cars
#14 |
I'm there again. Alternator has been changed.
At low RPM like 3,000 on 4th gear, it has a hesitation before going higher in the RPMs. And the engine stalls at idle. Any quick idea? Should it be a big concern? Pretty much ALL the problems stated above were fixed. Thanks for your help guys! |
#15 |
![]() Join Date: Apr 2004
Could be as simple as a bad idle air control. I would suggest hooking a scanner to it and going for a drive. Good luck.
#16 |
If it were me I'd pass,too many unexplained issues. Regardles of the price by the time everything -easy- has been repaired the low buy in price won't matter.
#17 | |
One thing, when people replace alternators they typically do it wrong and have it rebuilt incorrectly or buy aftermarket and it fails relatively soon. Find out where they purchased it and get a receipt Check the specifics on the carfax. If few owners and no "stories" I think this is a super buy! Many cars can have issues and they can build up. Hence the very reasonable price As far as the acceleration issues. Looks like injectors and that is a typical issue with ZR-1's. While your at it. Change the coil packs and other maintenance issues Sorry didn't notice a discussion over condition of the paint and interior. Check the weatherstrip. Is it crisp? How is the windshield? Does it have the lamination and radar cutout? How is the leather interior? Wear on the drivers bolster? (Typical). Radio / cd work? If issues Normal!! How about condition of the wheels? Tires new? Or original GSC tires Good luck. Sounds like a car with potential! ![]() David |
#18 |
Thank you David! I finally took the decision - I bought the car. I'm confident it can be restored to a very good condition. That stalling issue is the main problem. Got the codes pulled by a GM scanner and it doesn't receive any signal from the Camshaft Position Sensor. Should I change it first or it could be some other stuff around?
#19 |
![]() Join Date: Jun 2015
If you have a bad cam sensor you should have a code 31 and a light on the panel, plus full power won't work either. Its easy to change the sensor.
#20 |
![]() Join Date: Jan 2015
Congratulations! I'm sure you're going to be very happy with your decision. I got my ZR-1 in rough condition for a low price, and it has worked out great for me. I've had it less that a year and it's already 95% great. Having to work through the different issues helps you get familiar (even intimate :-) with it. Luckily for us the LT-5 parts are very reliable, the rest of the car is common C4, and there is fantastic support here and from our vendors.
