10-09-2015 | #31 | |
Re: Clutch Out, Which Should I Buy?
All components are the same with the single exception being the HRB/Hydraulic Release Bearing, due to the difference in bore size, just like the stock throw out/release bearing.
10-09-2015 | #32 |
Paul, I'll have a better idea of my experiance with my set up first of the week. I'll be communicating with both Ram and Jerry after my trip to Conn. this weekend. Their response will affect my overall happiness of the system. -Steve
10-09-2015 | #33 |
where did you get that price on the Henderson Tune?
10-10-2015 | #34 |
as far as clutch noise goes, a friend of mine had his stock flywheel replaced with a fidanza unit. the installer used a custom sprung hub clutch and it does not make any noise at all. It sounds like a stock set up. I am having that very same thing done to mine as we speak. fidanza flywheel with sprung hub clutch. there is lots to gain in a light flywheel.
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
10-10-2015 | #35 |
Ed,
Yep. Sprung hub disk. Works well.
10-10-2015 | #36 | |
Fidanza...YOU-WILL-LOVE-IT!
10-13-2015 | #37 |
Does the sprung hub contact the pressure plate fully, like the original?
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
10-13-2015 | #38 |
The sprung hub itself fits into the "pocket" of the flywheel where the mounting bolts are found. Of course the disc solidly contacts the FW face. Prior to going w a dual clutch, Pete's car used the Camaro disc w no slippage.
10-13-2015 | #39 |
Well, just for clarification... Pete went through a number of clutches in that car. The Valeo clutches worked when they worked, but I can remember at least one clutch was replaced just prior to installing the RAM dual disc setup. Of course Pete could tell us for sure how many other clutches he wore out in the course of drag racing that beast.
10-13-2015 | #40 |
My point was that the Camaro disc was able to take ZR to 11.0's, so for stock or lightly modified applications it's a pretty good alternative. It's worked fine in my ZR for a number of years.
