Old 09-23-2015   #11
dredgeguy
dredgeguy's Avatar
Default Re: Second time for Secondchance
The new fashion imported from Cairo....
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-23-2015   #12
Gunny
Gunny's Avatar
Charlie's moonlighting as a proctologist
Gunny is offline   Reply With Quote
Old 09-23-2015   #13
dredgeguy
dredgeguy's Avatar
Line up boys, volume discounts available. Small hands and fingers are a bonus
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 09-23-2015   #14
This is pretty cool, my daughter has autism, and something like this means alot....very nice of you guys to do this!
All credit goes to Dempsey. I thought it was very thoughtful of him to invite Brett.
Old 09-23-2015   #15
Upon head removal, head gasket failure was confirmed. I couldn't make Sunday but according to Dempsey inboard head bolts didn't take much force to unbolt. So, it seems quite feasible that failure may have been due to improper torque when the short block was assembled at the machine shop. Another possibility raised was detonation in #5 and #2 cylinder.
Heads are being shaved and cleaned and we will be making sure that all liners are level and have correct projection above the deck.
Another concern I had was very low oil pressure after the rebuild/install last year. I had about 10 psi at idle when the coolant reached 200 degrees. Well, guess what showed up in the oil pan?! - crankshaft oil plug!
In a way, head gasket failure was a blessing in disguise - forced me to pull the motor and resolve not only blown head gasket but also low oil pressure concern.
For those planning on off-set grind mini stroker crankshaft, make sure to instruct the machine shop to install plugs after the heat treatment. Rich (Scrrem) had the same issue.
Old 09-23-2015   #16
Actually this is the Third time this happened. My 380 was the first 380 install and the first to crap the crank plug in 2012. I highly suggest welding the expansion style crank plugs in. Thats the only way I would recommend to move forward. My tale of woe is below. Now that the pan is removed make sure the bottom side of the pistons are not damaged as well from the plug beating around in there. GC
http://www.zr1.net/forum/showthread....ght=crank+plug
Old 09-23-2015   #17
Can we get a ZR-1 Registry tshirt for Bill?
Old 09-23-2015   #18
That's a great idea. I'll go half with you.
I'll talk to Mark H. and work it out.
Old 09-24-2015   #19
dredgeguy
dredgeguy's Avatar
Brett and his Mom came to our local cars and coffee last Sunday and they enjoyed seeing all the cars including Matt's and my Z. Think we have a fan for life
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 09-24-2015   #20
An honorary WAZOO member!
