09-01-2015 | #1 |
Coolant drain question..
Figured I would throw this one out there..
Sending out the plenum and injector housings for porting soon.. I heard you have to drain some of the coolant first...Did not get a chance to give it a really good look, but is there a petcock screw on the bottom of the radiator? I'm sure there is the car is a 91.....Is it easy to access? Will it be visible when I get underneath the car? How much should I drain? Thank you... Last edited by Vette73; 09-01-2015 at 07:42 PM. Reason: Spelling |
09-01-2015 | #2 |
Re: Coolant drain question..
Bottom passenger side. About a Coffee can full.
09-02-2015 | #3 |
Very good ....Thanks...
09-09-2015 | #4 |
If you feel around for it then use a pair of pliers to open you dont even have to jack up the car.
09-14-2015 | #5 |
Looking now....Does it look like a regular petcock screw? Reall don't see it right now....
09-14-2015 | #6 | |
This picture might help... Last edited by KPW; 09-14-2015 at 07:12 PM. Reason: added picture |
09-14-2015 | #7 |
Yes yes found it.....Thanks so much....
