Old 08-15-2015   #61
edram454
edram454's Avatar
Default Re: Point/Counterpoint: DOHC v OHV
Originally Posted by pantera1683 View Post
Big Block?
Im surprised nobody caught it sooner. BB?
ed ramos #3028
Old 08-15-2015   #62
ed ramos #3028
thought that was standard short hand.
Old 08-15-2015   #63
Although it's a 427, that doesn't make it a big block. It's still an LSx block just a bigger bore. I may be oversimplifying it.
Old 08-15-2015   #64
fair point, well made and nicely presented. I'd forgotten that the ls7 was a sbc
Old 08-16-2015   #65
Fully Vetted
Fully Vetted's Avatar
My mistake. I thought it was a BB.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-16-2015   #66
mike100
The LSx all have the same block dimension, but I took at as any v8 over 400 cubic inches to be a "big block" as the historical packaging generally had its threshold at about that size.
Old 08-16-2015   #67
Fully Vetted
I had a 70 1/2 TA that had a 400 small block (Ram Air III). If I'm not mistaken the "small block/big block" designation was only applied to Chevy engines, tho. But the Pontiac 400 was always referred to as a small block.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 08-16-2015   #68
396 was a big block back in the day, so displacement was not the determination for the designation. BB cylinder heads would not work on a small block and vice versa.
Old 08-16-2015   #69
I thought it had to do with the bore spacing?
Old 08-16-2015   #70
Well you could say bore spacing has something to do with it. Here's a very illustrative video of the difference. The name "big block" becomes pretty obvious.
http://youtu.be/LPZuEWli4gQ
