Old 07-22-2015   #11
Roadster
Roadster's Avatar
Default Re: Have your Climate Control Buttons ever not respond to your commands???
Thanks Tom that cleans up the mystery so to speak.
Glad the mystery is solved Daryll.... used the ZR-1 again for work and it's nice and cold in the cabin....
Originally Posted by John Boothby View Post
Mine was iffy when I bought the car 10 years ago and I had read in this forum about cleaning the contacts. I took mine apart and cleaned the contacts and it has worked flawlesly ever since. Easy job also! Also Dr. Don did his number on my radio/cd/cassett and speakers. Also replace the power antenna with a complete new unit.
I think I might have to replace the antenna also, have to check underneath the back panel, as I hear it moving around when going up & down. Hopefully it's loose and needs to be tighten.
Also the two torx screws in the center top air vent turned out to be T15 on my 94, instead of T20 as mentioned in the video. Don't know if this was a running change, or someone used different screws on mine.
1974 LS4 454 Vert
1974 L-82 355 Vert.
