Old 07-10-2015   #1
Pat Cooke
Default Rev Limiter
Hi,
I am entered in my first hillclimb on Sunday, can anybody tell me if my 1990
ZR1 has a rev limiter ?
Regards
Pat in England
Pat Cooke is offline   Reply With Quote
Old 07-10-2015   #2
Default Re: Rev Limiter
Yes. IIRC, the stock 90 imiter is approx 7100 rpm.
However, due to the normal lag in the analog tach movement, you may experience the affect of the limiter before the tach reads 7000+ rpm, especially at WOT in the low(er) gears.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-10-2015   #3
Pat Cooke
Many Thanks for your response !! Impressive !
Excuse my ignorance what is WOT ?
Old 07-10-2015   #4
If you have the stock chip you should be able to see the shift light that tells you when to shift
Old 07-10-2015   #5
5ABI VT
Wide Open Throttle
Old 07-10-2015   #6
Pat Cooke
Cool Re: Rev Limiter
Thank you !http://www.zr1.net/forum/images/icons/icon6.gif
Old 07-10-2015   #7
PhillipsLT5
PhillipsLT5's Avatar
Do not keep it over 6200 for a period of time, water pump cavitation
Old 07-10-2015   #8
True enough. But the rev limeter is @ a higher rpm than the shift light trigger.
90 #1202
Sans secondaries
Old 07-11-2015   #9
Hib Halverson
Hi,
Regards
Pat in England
Your LT5 engine has a rev limit at 7072-RPM, but keep in mind that the LT5 doesn't make a whole lot of power beyond 6500 or so. In a hill climb, especially on with lots of curves and few or no long straights, you're going to be better to use a gear change strategy which keeps the engine between peak torque and peak power rather than up near the rev limit. Also, keep in mind that a rev limiter will not protect you from overrev on a improper downshift or "downchange" as some of you Brits say.
Good luck, Pat!
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
