#51 | |
![]() Join Date: Jun 2005
That radiator is a universal C4 replacement in that it has the transmission EOC in the right side tank. Obviously, the ZR-1 would not use those connections. Lastly, Amazon lists the seller at "Auto Dynasty". Try and find them on the web. Good luck. If you want to buy that radiator make sure you understand the manufacturer's warranty before you enter your credit card number.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 06-28-2015 at 12:11 PM. Reason: Added content. |
#52 |
![]() Join Date: Aug 2012
I just purchased a DeWitt radiator and a set of new hoses from Jerry's. Looking forward to getting it installed. Last week in 92 degree heat got stuck in traffic and temp was pegged before I noticed it. Almost had a stroke......checked the digital gauge and it was 258! Turned off the A/C, turned on the heater and good luck was with me. Traffic opened up and I got to 70 MPH and it cooled down to 202 in a couple of minutes. Then I went home, cleaned my pants and ordered a the same radiator recommended by fellow Wazoo, SecondChance.
Charlie __________ Dredgeguy WAZOO Member 1992 Bright Red/Black ZR1 #246 Dana 4:10 gears Polished LT5 by Haibeck Polished Fikse FM5's with Michelin Pilot Sport 2 Stainless Works headers and cats with Corsa Last edited by dredgeguy; 06-28-2015 at 05:54 PM. |
#53 |
![]() Join Date: Nov 2011
Charlie, is that 158 suppose to be 258?
#54 |
10-4 on that, it should have been 258, made the edit correction. Just thinking about it still shakes me up as you can see.
#55 |
Minga, I'd have had the hood open, blowing on the engine. That's hot.
#56 |
I was afraid it was gonna blow!
#57 |
They tell me it's a pretty hearty engine.
#58 | |
You do not have to cut or modify the Radiator Housing when you remove the radiator but let the engine sit overnight and remove the Oil Cooler Adapter setting the hoses and adapter off to the side (do not disconnect them from Oil Filter Adapter). That will allow you to lift the Radiator Housing up on the Drivers side followed by lifting (bending the tab a bit) the Radiator Housing on the Passenger side last. Reverse for Installation of the Radiator Housing after New Radiator installed. It is easiest to separate the Thermostat Housing so you can remove the Bottom Radiator Hose (may take a razor blade to cut hose lengthwise to get it off stock radiator). Remove Thermostat and may want to install new thermostat when you are at it. I remove the two (13mm head) bolts holding the thermostat housing to the frame before I remove the three (13mm heads) thermostat Housing Bolts. One short bolt holding the thermostat housing to the bracket and one long bolt holding the thermostat housing to the bracket also and holding the thermostat housing halves together with the third long bolt. It is a bit tricky holding the thermostat in place when assembling (use a putty knife). the new or old thermostat making sure the rubber thermostat gasket is not misplaced. There is a bit of a science to refill with coolant but if water pump is not drained you should be fine when refilling the reservoir in front of the Passenger Side windshield with coolant (slowly as air should bubble back from vent hose at top of radiator). Make sure the two Injector Housing Coolant Manifolds are getting warm within one minute after firing up the engine. Before the radiator pressure rises, turn the engine off several times and add coolant to the Coolant reservoir on passenger side just in front of windshield.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-29-2015 at 02:35 AM. |
#59 |
Can a stock clean radiator provide enough cooling for the LT5? It seems that the aftermarket units really help it cool the way it should have from the factory.
#60 | ||
That is my experience with several stock radiators but I can honestly say I have never had a correctly cleaned stock radiator to work with (only thought I did). You have to remove the radiator to clean it properly and also clean the AC Condenser and Oil Cooler with the Radiator Removed as Jim (QB93Z) Describes. I think Jim (QB93Z) had some luck with a properly cleaned stock radiator on his AZ trip but Jim would have to describe that situation including the temperatures and if he was in traffic. I have some thinking on Fans (GOLDCYLON has experience with fans) and Thermostats as well as chips to turn fans on at lower temperatures. As I recall the stock fans turn on at Temperatures in the 220 deg or higher range (maybe 228 deg F) which leads me to believe it was expected that the LT5 might run that HOT. Quote:
![]() Got almost to cross hatched area and I shut it down. Took a while to figure that one out ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-30-2015 at 08:31 AM. |
