Old 05-22-2015   #1
SteveCanyon
Default Whistle on startup
I am getting a loud whistle when I start my car for the first start of the day. Almost sounds like a supercharger whistle if that makes sense. Goes away after about a minute. The only thing I have changed is the coolant, wondering if there is some air in the system that is cycling out? Any other ideas?
SteveCanyon is offline   Reply With Quote
Old 05-22-2015   #2
Franke
Default Re: Whistle on startup
I wonder if it could be your A.I.R. pump running. It runs to help bring the cats up to temp etc. then shuts off.
Old 05-23-2015   #3
QB93Z
QB93Z's Avatar
Can you tell where the sound comes from? Left or right, front or back? The AIR system is a likely candidate, but it runs every time you start the engine. You mentioned the noise happens on the first start of the day.
If you think it is coolant related, start the car with the coolant cap off, but don't run it too long that way.
Does it make a difference if the clutch is in or out?
Old 05-23-2015   #4
SteveCanyon
No change with the clutch. I will try to get some video and will try pulling the radiator cap too.
Old 05-23-2015   #5
BigJohn
BigJohn's Avatar
That's funny, mine has always made that sound!
Old 05-23-2015   #6
Try starting with AC turned off. If that stops the noise its refrigerant noise.
Old 05-23-2015   #7
SteveCanyon
Does it without the AC on.
Old 05-23-2015   #8
SteveCanyon
It might be normal, just curious what is causing it.
Old 05-23-2015   #9
Arctic91
Arctic91's Avatar
AIR system most likely... same with my '91. You can probably feel the pump vibrating when it's operating and change when it turns off.
Scott
Arctic91 is offline   Reply With Quote
Old 05-23-2015   #10
Jagdpanzer
Jagdpanzer's Avatar
To bad Bogie isn't still with us. A lot of us remember how well he handled incounters involving whistles.
https://www.youtube.com/watch?v=MheNUWyROv8
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
