Old 08-15-2007   #11
8upZR1
8upZR1's Avatar
Default Re: Intermittent high level brake light
All ZR1 owners over 200 lbs who crawl under the dash to remove the brake switrch or booster bolts should have an assistant within shouting range. I have often found myself stuck under there, ussually after longer periods where my arms are too tired to pull my fat a$$ out of that tiny space. Definetely not for the clostrophobics.
Old 08-17-2007   #12
thxalot
GMpartsdirect.com has the $9 price. Shipping was too steep at $11, so I wound up heading over to the local Chevy counter where I got it for $14 after a 20% discount for Corvette Club members.
Nice numbers on the dyno. 325HP is good for a stock ride. I remember reading that Corey Henderson has a tune which will lay down 409HP with exactly what you've got (cat-back+headers+port&polish). You might want to enquire about that. even if it's on a Dynojet, that's still 25 extra ponies for not too much dough.
If you do, let me know how you make out. I'd like to get down that same road myself one of these days.
-Burt
thxalot is offline   Reply With Quote
