Old 04-13-2015   #1
spork2367
Default block corrosion
So this showed up on ebay. I've never seen a used block that had that much corrosion, in fact, most have virtually none. So what were they doing wrong?
Old 04-13-2015   #2
tccrab
tccrab's Avatar
Default Re: block corrosion
I would guess in an un-heated, un-cooled, non insulated storage in a high humidity and maybe even salt air environment.
'Crabs
Old 04-13-2015   #3
Scrrem
Scrrem's Avatar
'Crabs
If this is Kurt's block, that FL salt air will do that to aluminum in short order.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Scrrem is online now   Reply With Quote
Old 04-13-2015   #4
spork2367
Most of the corrosion appears to have happened while the engine was assembled. So I doubt it was sitting in a shed or yard. Just curious as I've never seen one that corroded. The one I'm rebuilding now had 113,000 and virtually no corrosion.
Old 04-13-2015   #5
Jagdpanzer
Jagdpanzer's Avatar
Must have laid around for some time with the iron liners still in it.
Probably would have faired better with the original aluminum liners.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-13-2015   #6
spork2367
Didn't think about the iron liners sitting in it. I'm sure that was it....eek!
