Old 03-06-2015   #1
Default Fuel Rail/Fuel Pressure Regulator
I am looking for a Fuel Pressure Regulator and I am assuming the whole Fuel Rail with the hard lines/connectors/"O" rings between the Regulator and Rails. Ran into a Fuel Pressure Regulator Failure yesterday with Raw Gas sucked into the Plenum. It is Rare but Happens
I have not figured out how to take a Fuel Pressure Regulator apart but apparently the air controlled valve/bellows totally failed with raw gas being forced out through the vacuum port and sucked into the Plenum from the Fuel Rails.
Old 03-06-2015   #2
Default Re: Fuel Rail/Fuel Pressure Regulator
Ruptured diaphram. The stock regulator is not made to be servicable. There are alternatives besides replacement with a stock style regulator.
All you need is just the regulator. I have the o-rings, PN 14104675-9V and also a stock replacement regulator.
However, YOU would LIKE this! Would be nice n' blingy with braided SS lines & look cool mounted on the RH side of the plenum.
http://www.ebay.com/itm/AEM-Performa...item35dd9b26ae
OR..... in your color
http://www.dezod.com/pd_aeromotive_a...regulator-.cfm
Come to think of it, I may want to do this myself!
Old 03-06-2015   #3
You know me too well Jerry
Thanks for the information.......I had no clue you sold the Fuel Pressure Regulator separately
Old 03-06-2015   #4
Yep, under Fuel System Category
Considering you are one of my most prolific customers, and the time span, I've had plenty of opportunity to get to know you..... and glad of it!
Old 03-06-2015   #5
RussMcB
Seems like it would be a challenge to use an aftermarket pressure regulator with our hard lines. Where and how would you plumb it?
Just curious.
Old 03-06-2015   #6
Just remember your FIRST online customer
BTW Jerry any new hats? I need to order a few things.. My DD hat is taking a beating lol and its been washed twice
Old 03-06-2015   #7
Just curious.
Braided SS lines
1.Single unregulated supply line to regulator,
2. (a) If regulator equipped for 2 regulated outlet lines, then 1 to each rail.
If not, then (b) single regulated line to Tee fitting + line from each end of Tee run to each rail.
3. Regulator return to return fuel line
Fuel Rails modifications.
1. Weld shut all rail holes for fuel pipe connections between rails
2. Weld AN fittings on firewall end of fuel rails for regulated fuel pressure lines.
3. Mount liquid filled analog gauge direct to regulator
I have a set of modified fuel rails somewhere. Will take photo later if interested.
The benefit is constant fuel pressure at all manifold pressures, from max vacuum to zero or positive pressure if boosted.
Old 03-06-2015   #8
I will never forget that Daryl! Order #0001
I have in stock, but the same original design. Do you have an idea for a new design?
Old 03-06-2015   #9
Maybe the ZR-1 script like our rear end logo, I like the splash logo as well and I can display my my splash pin to it as well like I have on your current hat.
Old 03-06-2015   #10
What about the hat style itself, the soft, black denim. Is that still the preferred type? Maybe "Beanies" are the thing at the moment, especially for the NE part of the country.
