Old 01-04-2015   #1
PhillipsLT5
PhillipsLT5's Avatar
Default Suggestions for Battery Tender
Seller/Make/Model # ??
Old 01-04-2015   #2
8cam
Default Re: Suggestions for Battery Tender
I have a Schumacher 1.5 amp in the 308, works very well.
'90 ZR-1 #1322 Daily Driver, 64k and counting
Black/Gray
[IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG]
Old 01-04-2015   #3
Billy Mild
I use the Harbor Freight one. It works fine for float charger or as a true tender. Its not meant to bring a battery back to life.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 01-04-2015   #4
PhillipsLT5
I am trying to keep it charged for 1 or 2 months
Old 01-04-2015   #5
Karl
Karl's Avatar
I use a battery tender jr from O'Reilly auto parts.
http://www.oreillyauto.com/site/c/de...0360&ppt=C0005
1985 L98 Blue On Blue *Sold*
Old 01-04-2015   #6
Billy Mild
The one from Harbor Freight battery tender would suffice. I use mine for motorcycle batteries and old car batteries. I haven't had any issues. If the battery is below 11 volts you need something different. For maintaining and slight recharging they are fine.
If the battery is sulfated then look for a Battery Minder or CTek charger.
Looking for a ZR-1
Old 01-05-2015   #7
JimZRyd
JimZRyd's Avatar
Battery Tender plus here. Picked it up at the museum. Has worked great for years!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 01-05-2015   #8
edram454
edram454's Avatar
battery tender plus can be picked up on ebay for 34 bucks shipped. always have my zr1 on it and my scooter also. Your battery will last forever, or it will seem like it.
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 01-05-2015   #9
For maintenance:
I have the original "smart" charger; the Battery Tender(s) on all but one car. The battery on my wife's 69 C3 has been on the BT for 9 years, come spring, and it still cranks that 11:1 compression L46 like new. These chargers are 800 mA for the single chargers to 1.5 A for the dual output charger (one).
For charging:
For actual charging, I've had an inexpensive, automatic, Black and Decker (smart) charger for over 12 years. It can be configured for several types of batteries (wet, gel, etc) and max charge rates from 4, 10, 20, & 40 amperes, as well as several other battery conditioning modes as well: a decent unit for home/hobby use. It too is a smart charger, in that it will monitor and shut off when the battery is at full charge. And, it will periodically turn on to keep the battery topped off and prevent sulfating. (Also has a de-sulfating mode, if the battery is in such condition to require more than just preventative maintenance.)
For "dead" batteries:
I've had good success reviving batteries that appear to be totally dead, due to leaving the lights on (or the like), by using the old fashioned "dumb" charger: nothing automatic about it. Once the battery takes on enough of a charge to satisfy the threshold level, then the automatic chargers will recognize that fact and take over.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-05-2015   #10
I would suggest getting a float charger from the National Corvette Museum store. That is what I did. It is more expensive than the auto chain stores but you are supporting a great Corvette institution in the process. --Bob
