![]() Join Date: Feb 2009
Those of you that have done motor pulls, do you disconnect and remove the power steering pump or just leave it connected and moved to the side?
Rich
Rich,
I removed it with the engine so I could give it a thurough inspection and cleaning. Then filled it with fresh fluid after reinstalling the engine. Be sure to use a proper tubing wrench when disconnecting the pressure line to the power steering unit.
Thanks Phil!!
Rich
#4 | |
Also............I installed LT5s with SW Headers attached. Makes it very easy to install the Header Bolts.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-06-2014 at 09:27 PM. |
