#11 |
![]() Join Date: Jan 2010
#12 |
Make sure you test the integrity of the plenum runner walls. Not sure how far you ported it but you'd be surprised where it gets thin, especially short side radius. I ported mine to 36.5mm and we found some extremely thin (paper thin) walls which gave way once I did media blasting of plenum.
#13 |
![]() Join Date: Aug 2006
#14 | ||
I have thermal compound for CPU heat sinks. Yay or nay? ![]() |
#15 |
![]() Join Date: Nov 2007
Heat sink compound is required, so CPU paste should do the trick,
Two things: THINNER IS BETTER: Just enough to fill the microscopic grooves left over from when the surfaces were fly-cut is all that should be used. Adding more actually increases the insulation between the heat sink and the "device" to be cooled. If the layer is so thin as to be practically translucent, that is good. No gaps, but NO MORE. ABSOLUTELY CLEAN: Be careful that the surfaces are free on any foreign debris, e.g., chips or (especially) sand/grit, etc. Good luck. |
#16 | |
