![]() Join Date: Nov 2013
Hey Everybody,
What's the level of difficulty and time required to swap out the U-Joints of the half shafts. The FSM guidance looks pretty straight forward...is a hydraulic press for a must for the caps? Thanks! Rich |
![]() Join Date: Jul 2007
Yes the press will help.. however I have swapped them with sockets and a vise, just a but more time consuming than having a press..
#3 | |
![]() Join Date: Nov 2007
*The relatively LOW rpm of the half-shafts may exclude them from need of further balancing. P. |
![]() Join Date: Feb 2011
It takes more effort to get the half-shafts out of the car then it does to install the u-joint on a bench imo.
I have done two sets now and I have used sockets and hammers. I would have purchased a dedicated tool, but the aluminum yokes proved to be so easy to work with I have not bothered. It is absolutely imperative that you use the brand name Spicer u-joints or no guarantee that the new ones won't be a tight fit. Those $12 parts store imports will really need to be pounded in compared to genuine Spicer parts. believe me on this. I also used 25 lb lead bricks I got surplus from a university to set the aluminum shafts on so they wouldn't get dinged up during the process. U can't really do this on a wooden work bench- you might have to get down on the garage floor (hence my soft lead bricks so I can do it on a bench). |
![]() Join Date: Mar 2004
DANA SPICER 5-1350X or DANA SPICER 5-3615X on the half shafts.
Thank you all! Would you say this job is easy, takes ~5hrs?
A good u-joint source I've used on several occasions:
http://www.dennysdriveshaft.com/c37_u_joints.html ![]()
#8 | |
![]() Join Date: Sep 2012
Hello Phil,
I need to replace the half shafts in my 95. Would this be the ones that I need? Thanks, Nelson007 http://www.dennysdriveshaft.com/p423...ebuild_ki.html
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
#10 |
Nelson
That kit will do both half shafts and the drive shaft plus replace all bolts and straps. Its the one I always go with. That way you don't have to look back.
