Old 06-28-2007   #1
blackjack
Default bits 'n pieces
fot those of you who have problems finding the right torx screw,many of them are available at your friendly harley dealer,specialy the black ones
bj
blackjack is offline   Reply With Quote
Old 06-29-2007   #2
Default Re: bits 'n pieces
Thanks bj!
Old 06-29-2007   #3
evl_twn
evl_twn's Avatar
Don't use those! Your Z will start to leak oil!
evl_twn is offline   Reply With Quote
Old 06-29-2007   #4
what da ya mean, my Z is a Z ......so it already leaks oil....that was included in the MSRP!
Old 06-30-2007   #5
blackjack
hey...they dont leak...they mark their territory
bj
Old 07-04-2007   #6
Nick
At least if its leaking you know there's still fluid in there!
I once owned a Range Rover, and the front wheel hubs had gear oil resevoirs that leaked constantly. I called the repair shop to tell them about the leaks and set up an appointment to fix them, and they told me that was normal, and that when it STOPS leaking to start worrying, because the resevoirs would be out of fluid!
Good tip on the torx screws; thanks!
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
