Old 10-10-2014   #1
Vetman
Vetman's Avatar
Default Oil pan bolts
I know this has been discussed numerous times in the past. My question is to tighten all the oil pan bolts what has to be removed?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 10-10-2014   #2
Default Re: Oil pan bolts
You should be able to remove the two beams that attach to the rails and from cross member. The engine and mounts are actually sitting on a thick plate(cradle)....so the beam are not supporting the engine; the plate along with the transmisson beams will support the motor w/o the beams....
Old 10-10-2014   #3
Vetman
Vetman's Avatar
My second question is concerning the two inch diameter oil spot that appears under the front of the engine, passenger side, every time I park the car. Could this oil be from the cooler lines? Car is stock 67,000 mi. Not driven hard.
1990 Z # 2441
Old 10-10-2014   #4
Oil cooler lines or one of the 2 oil pressure sensors......
Old 10-10-2014   #5
Vetman
Vetman's Avatar
Thank you!! You are a wealth of knowledge. I want to get this taken care of before my four day drive to the gathering in May. Can't wait to make the trip!
1990 Z # 2441
Old 10-10-2014   #6
I will post some pics this weekend of the cross members/oil sensors
Old 10-10-2014   #7
Vetman
Vetman's Avatar
Since I have you on line. If the cooler lines are the culprit are they available locally like a dealer? If the oil sensors are bad, where I get them?
1990 Z # 2441
Old 10-10-2014   #8
Potential Oil Leaks and the OPRV Cover Plate
Oil Filter Adapter Functions
Jerry's Gaskets has the Sensors and Switches in stock.
Some of us make our own SS with Reusable Fittings Oil Cooler Lines. Those that make their own hoses usually have the original Oil Cooler Hose Assemblies which had shown NO leaks before removal for Resale as you like on Ebay.
Jerry's Gaskets Also has New Oil Cooler Hose Assemblies in SS Braid or Black Braid.
ZR1 Engine (LT5) Bolts and Hydraulics
Old 10-10-2014   #9
Vetman
Vetman's Avatar
Thanks. I will order from jerry! Is this a relatively easy job?
1990 Z # 2441
Old 10-10-2014   #10
To help you find the items Lee defined as possible oil leak source.
You have 2 styles of hoses to choose from, black-braided and SS braided
BLACK
http://jerrysgaskets.com/store2/root...roducts_id=888
Stainless
http://jerrysgaskets.com/store2/root...roducts_id=887
The two oil pressure units (1 is a switch, the other is a sender) Lee referred to
Switch
http://jerrysgaskets.com/store2/root...roducts_id=346
Sender (Big one on top)
http://jerrysgaskets.com/store2/root...roducts_id=106
