Old 10-08-2014   #51
Default Re: Pulling the Plenum for the first time...
Originally Posted by Billy Mild View Post
My vacuum pump runs for literally 1 second then shuts off. The system appears to be pretty tight as far as that goes. It doesn't seem to leak from that aspect. Everything was ZIP-Tied and and any pieces that didn't seal well with a vacuum pump were replaced.
I have leaking fuel from under my plenum. It didn't do this the night I got the work complete, and it didn't leak yesterday. It must have done this overnight. So I guess the plenum is coming back off?
I know I have a vac leak that I just haven't dealt with yet and my pump does the same thing
Old 10-09-2014   #52
Billy Mild
If I did have a vacuum leak, wouldn't the idle be fluctuate all the time? I just don't see who it could be leaking. I have used a vacuum pump to check all the connections and nothing seems to be leaking.
Old 10-15-2014   #53
Billy Mild
Here is a little video of what I am dealing with when the car is fully warmed up.
http://youtu.be/TjD4C59Q9gA
Old 10-16-2014   #54
Billy Mild
I had a suggestion from Marc Haibeck that it could be the PCV grommet for the valves. I checked that today and it was ziptied to the tops of the PCV valves. Is there anyway to pressure test that system?
Another thing I noticed today. If the AC is on the idle is pretty much perfect. It doesn't fluctuate at all. Is that normal? Could this all be IAC related?
Old 10-16-2014   #55
That's because the AC put a load on the motor and moved the idle to a different/richer part of the VE table. Suggests to me that your oscillating idle is due to a lean surge. The VE table at idle needs to be flattened out, probably along w the SA table altho I would look at Closed Throttle Idle SA setting.
Old 10-17-2014   #56
Billy Mild
This sounds like a tuning issue. My car is pretty much stock minus the K&N air filter, and the center resonator delete and borla mufflers. Would that cause a lean surge at idle? I would think the stock FI system could handle those changes.
Old 10-20-2014   #57
Billy Mild
Any idea on what to look at?
