Old 08-28-2014   #11
Default Re: Help identifying parts
Originally Posted by phrogs View Post
You need the two nuts and one screw for the throttle body cover as well, I can't recall the official name but I doubt I have one of these, I might but doubt it. Check jerrysgaskets.com
And ebay as well.
That bolt someone has one . Jerry should
I thought it was called the Throttle Shield if memory serves me correctly
Old 08-28-2014   #12
WVZR-1
Accelerator cable control shield is GM nomenclature designation.
I likely should have mentioned:
Accelerator cable control splash shield - SPH is the accepted abbreviation for splash so cataloged you would see it as SHIELD, accelerator control cable shield SPH.
Old 08-28-2014   #13
And there you have it. Reminds me of the Army Nomenclature for a tooth pick.
Stimulator Interdermal - 1 Each
Old 10-06-2014   #14
Okiedoke
Okiedoke's Avatar
I finally had a chance to install the throttle body shield today. As far as I'm aware, this is the last missing piece and the LT5 should be complete now! Thanks again for everyone's help!
1991 ZR-1 #405 (white/black with blue pin stripes)
Okiedoke is offline   Reply With Quote
Old 10-06-2014   #15
Looks better !
