Old 08-14-2014   #21
badbob326
Default Re: Why don't they start right up?
I got my 1991 new, the start thing always be there. It seems the longer they sit the longer it takes.
badbob326 is offline   Reply With Quote
Old 08-14-2014   #22
Made in USA
Mine starts within 2 seconds tops. After reading the thread about the vapor canister, I just got a new one and am going to change it this weekend. We'll see if it changes anything.
Made in USA is offline   Reply With Quote
Old 08-14-2014   #23
badbob326
I also have a 90 DRM 600 it the same with the starting and no canister. It's just a ZR1 thing. Just do not over heat the starter it will be ok.
Old 08-15-2014   #24
I've always let the fuel pumps run until they quiet before rolling the starter.
When the 90 has been sitting for a week or more, it's a "Mississippi-one, Mississippi-two, Mississippi-three - aZOOM! But, after running some that day, it seems to fire anywhere between 1-2 seconds, if not before.
Ami's 91 Z, after passing through Pete's Mystery Garage, never seems to wait more than a second - IF THAT - before TURQ MONSTER roars to life.
Worth mentioning? I had a couple backfires on my 90, back when I first got it. But, later I read here to hold the starter ON for about half a second after it starts. Since I've been letting the pumps reach pressure AND holding the starter on a tad after it fires, I've never had a backfire since, IIRC. (Now that I went and said that, just watch it sneeze and blow all the hoses off!)
Old 08-15-2014   #25
Hog
Does the LT5 use a "wasted spark" ignition, or an ignition that fires the plug both during the compression stroke AND the exhaust stroke, or whenenever the piston is near TDC?
The reason I ask is because GM's other DOHC V8 the Northstar 4.6 liter V8 did use a "wasted spark" and my 300hp L37 Northstar would also require some extra cranking time before it started, even after letting the intake pump perform its pre programmed cycle when te ekey is in the run position, before turning further to crank the engine.
Old 08-15-2014   #26
Fully Vetted
Fully Vetted's Avatar
Strangest thing happened yesterday. I went to start it and decided to not wait at all. I just turned the key all the way and BAM! it started immediately. And it had been sitting for several days. Strange...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-16-2014   #27
8cam
I simply turn the key like a normal car, and mine fires almost instantly...like a normal car. In fact I had no idea there was a "start thing." Most of the time when I hear long start times, I suspect low fuel pressure. My car has had almost all fuel components replaced, and it clearly does not lose fuel pressure for a long time. Maybe this is just something that has happened over time? In any case it does not sound normal.
