Old 08-02-2014   #1
c4koh
c4koh's Avatar
Default Help? O-ring or no o-ring on bottom of 92 injector
Hi All,
Plenum's off, replacing the larger O-Ring seals on the primary injector housing and I have 16 identical injectors with blue O-seals on *top* and *bottom* from FIC.
Literature seems unsure as whether the bottom O-ring (on the flange) should be there or not there on the 1992. The 'Tech data' sheet seems to contradict it!
I can't see any harm in leaving the bottom o-ring on there, but any quick advice before I just go with my gut-feel (and 50% getting it right!) appreciated.
Steve
c4koh is offline   Reply With Quote
Old 08-02-2014   #2
c4koh
c4koh's Avatar
Default Re: Help? O-ring or no o-ring on bottom of 92 injector
OK, I re-read, and in summary I *think* I understand how it's written.
1993-95 new injectors: identical in design.
Small O-rings on both top and bottom tip / flange.
1990-92 (so what mine are):
Small o-rings on top.
*No* small o-ring on bottom tip/flange. Instead, larger O-ring fitted into IH which seals the injector.
Note: the reason for the question is that they came fitted already, both sets marked primary and secondary, with the smaller o-rings top and bottom. So just checking.
